@mikehank : M866 pre amp ....uuh what component are you pointing to i will add my log also to compare ;-)
boot + diag + spc ( diag gives All Pass)
--------------------------------------------------------------boot ----------------------------------------------------------
romPost: I am alive .
uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
romPost: L2 cache turned on.
romPost: MPC107 Walking-one passed.
romPost: MPC107 configuration passed.
romPost: Intel21555 PCITOPCI bridge configuration passed.
romPost: PERFORMING ROM CHECKSUM TEST...
romPost: ROM checksum passed.
romPost: PERFORMING DRAM CELL TEST...
romPost: Enabling data cache...
romPost: Data cache enabled.
romPost: Enabling instruction cache...
romPost: Instruction cache enabled.
romPost: DRAM Cell test passed.
romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF...
romPost: Disabling data Cache...
romPost: Data cache disabled.
romPost: Disabling instruction cache...
romPost: Instruction cache disabled.
romPost: Writing address to each *address...
romPost: Reading address from each *address...
romPost: DRAM march test passed...
romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON...
romPost: PERFORMING DRAM WALKING-ONE TEST...
romPost: DRAM Walking-one test passed.
romPost: PERFORMING NV-MEMORY WALKING-ONE TEST...
romPost: NV-MEMORY Walking-one test passed.
romPost: POWER-UP DIAGNOSTIC COMPLETE.
Hel
VxWorks System Boot
Copyright 1984-1996 Wind River Systems, Inc.
CPU: Tektronix HPP - IBM 750CXe
Version: 5.3.1
BSP version: 2.0.1.10
Creation date: Sep 30 2003, 07:53:07
Press any key to stop auto-boot...
0
auto-booting...
boot device : sm
processor number : 0
file name : c:/vxboot/vxWorks.st
inet on backplane (b): 192.168.0.1:ffffff00
host inet (h) : 192.168.0.2
gateway inet (g) : 192.168.0.1
flags (f) : 0x1008
target name (tn) : tds7000
startup script (s) : c:/vxboot/topscript.hw
Initializing backplane net with anchor at 0x1e80000... done.
Backplane anchor at 0x1e80000... Attaching network interface sm0... done
done.
Attaching networPC1 dio device driver installed
k interface lo0... done.
Attaching DIO client... done.
Loading c:/vxboot/vxWorks.st...1773468
Starting at 0x200000...
Host Name: bootHost
User: target
Initializing backplane net with anchor at 0x16e0000... done.
Backplane anchor at 0x16e0000... Attaching network interface sm0... done
done.
Attaching network interface lo0... done.
Adding 6034 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
CPU: Tektronix HPP - IBM 750CXe. Processor #0.
Memory Size: 0x2000000. BSP version 2.0.1.10.
WDB: Ready.
done
KERNEL: THERMAL CONTROL INITIATED
Executing startup script c:/vxboot/topscript.hw ...
dbFsIoctl: invalid code 3
################### topScript starts ###############################
cd "dbfs:c:/vxBoot"
value = 0 = 0x0
pDbDev = ramDevCreate(0, 512, 1152, 1152, 0)
new symbol "pDbDev" added to symbol table.
pDbDev = 0x1692d40: value = 23670112 = 0x1692d60 = pDbDev + 0x20
pDBfs = dosFsMkfs("/db", pDbDev)
new symbol "pDBfs" added to symbol table.
pDBfs = 0x1691720: value = 23669856 = 0x1692c60
ld < TekScope.o
value = 23657440 = 0x168fbe0
ld < TekScopeSM.o
value = 23660544 = 0x1690800
copy ("TekScope.DBF", "/db/TekScope.DBF")
value = 0 = 0x0
loggerInit
Serial No: B020198
value = 21822832 = 0x14cfd70
overrideFPdefaults()
value = 0 = 0x0
measurePPCtimebase
value = 0 = 0x0
registerMemPartitionSizes ( 0x00000000 )
value = 0 = 0x0
semInitForQueueCheckLogMsg
value = 23661184 = 0x1690a80
initSysWaiter()
value = 0 = 0x0
raxInit
value = 0 = 0x0
paiInit
done
value = 16129500 = 0xf61ddc = PaiBaseRegisterTable + 0x804
configureACL
SUCCESS
value = 0 = 0x0
verifyAcqBoardID
value = 0 = 0x0
tcsLoadTableToNVRAM "pc:c:/vxBoot/setup.tcs"
value = 0 = 0x0
updateAcqProcFirmware("dbfs:c:/vxBoot/acqProc.hex")
0x16987e0 (tShell): AVR FLASH contents match file dbfs:c:/vxBoot/acqProc.hex - n
o programming needed.
logTask: 1 log messages lost.
value = 1 = 0x1
cd "pc:"
value = 0 = 0x0
raxInitializeDevices
done
0x16987e0 (tShell): (Re)starting Acq Processor
value = 23692720 = 0x16985b0
excHookAdd(stopStressForException)
value = 15840048 = 0xf1b330 = stopStressForException
dsyInit
value = 0 = 0x0
dsyWPApplyNextRegs
value = 16110116 = 0xf5d224 = DsyRegisterTable + 0xbd0
# remove '#' from next line to set powerup scope state to factory default:
# NvramClearDb = 1
nvram_initFileSys
value = 21792992 = 0x14c88e0
TmgrInit("/db")
value = 0 = 0x0
PhxProxyInit
value = 20333280 = 0x13642e0
rtlInit
value =0 = 0x0
sysExtMemAddToPool memSysPartId,0x02000000,0x1c000000
value = 0 = 0x0
hwAccount_init
sysEnetAddrGet: 1b:15:41:8b:e4:21
Scope Model: CSA7404B
value = 255 = 0xff = DSP_cc_load_pri_byte_at_pri_load_ar1 + 0xd
GpibInit
value = 502600832 = 0x1df51480
wfmMemInit(1)
value = 62197472 = 0x3b50ee0
vertInstall
value = 62189956 = 0x3b4f184
calConStatus = cc_init(2)
0x16987e0 (tShell): Reading 358 bytes of service cal #1 data from NV[3:0] into 0
x3b4f000
0x16987e0 (tShell): nvMem_read succeeded
0x16987e0 (tShell): Complete PFCal NVRAM initialization.
0x16987e0 (tShell): Ready to Calibrate Probes.
calConStatus = 0x127d1dc: value = 33263 = 0x81ef
vertPostCalRestoreInstall
value = 0 = 0x0
MathMeasCreateTheMathandMeasurementLibraries
value = 61919168 = 0x3b0cfc0
initAcqMapper
0x16987e0 (tShell): initAcqMapper: Enter
value = 0 = 0x0
trigMapInit
value = 0 = 0x0
dsyMapInit
value = 0 = 0x0
mathMapperInit
value = 0 = 0x0
utilMapInit
value = 61913312 = 0x3b0b8e0
TmgrHookup
value = 0 = 0x0
PhxProxyHookup
value = 0 = 0x0
hookupAcqMapper
value = 19321872 = 0x126d410 = AcqMapperRtlDataList
MathMeasMapHookup
value = 23692552 = 0x1698508
dsyMapHookup
value = 23692656 = 0x1698570
utilMapHookup
value = 23692688 = 0x1698590
rtlHookup
value = 0 = 0x0
horizMapHookup
value = 23692648 = 0x1698568
fastFrameMapHookup
value = 23692672 = 0x1698580
trigMapHookup
value = 23692680 = 0x1698588
vertMapHookup
spcMapHookup
autosetMapHookup
value = 23692712 = 0x16985a8
timeSyncMapHookup
value = 23692704 = 0x16985a0
auxTrigMapHookup
dpoMapHookup
TmgrStartup
value = 61080848 = 0x3a40510
PhxProxyStartup
value = 61030304 = 0x3a33fa0
taskDelay(2)
value = 0 = 0x0
gpibHwInitC
value = 0 = 0x0
gpibTaskSpawn
value = 60904352 = 0x3a153a0
gpibIoInit "/dbios/DBIO005","/dbios/DBIO006"
value = 60854656 = 0x3a09180
enablePowerupDiags = 0
enablePowerupDiags = 0x123dbdc: value = 0 = 0x0
runPowerupDiags
done
dipSwitch = 0x0, enablePowerupDiags = 0, puMode=0
CalDiagPowerUpDiagsEnabled = 0
!! SKIPPING POWERUP DIAGNOSTICS !!
<< POWERUP DIAGS FINISHED >>
execution time 0 sec>>
Test "351" - Acquisition-->HFStep-->PhaseCal started
Test execution time 20.7 sec
value = 0 = 0x0
rtlStartup
value = 0 = 0x0
tsComp
value = 0 = 0x0
paiPrintVersionNumber
Pai version: 4.52
value = 18 = 0x12
################### topScript ends ###############################
Done executing startup script c:/vxboot/topscript.hw
KERNEL: RUNNING TIME SLICED AT 10 TICKS PER SLICE!
-> 0x3812b40 (aAcqExecutor): 24OCT22 12:28:33 U
--------------------------------------------------------------Diagnostics ----------------------------------------------------------
DIAGNOSTIC EXECUTION begin
Test "111" - Processor-->Memory-->DRAMWalk1 started
Test execution time 6.8269e-06 sec
Test "112" - Processor-->Memory-->DRAMCell started
Test execution time 0.050551 sec
Test "113" - Processor-->Memory-->DRAMMarch started
Test execution time 0.015118 sec
Test "121" - Processor-->PCI Bus-->Scan Test started
Test execution time 1.7933e-05 sec
Test "211" - RegAccess-->DACs-->Daculator started
Test execution time 0.00037678 sec
Test "221" - RegAccess-->Direct R/W-->DEMUX started
Test execution time 0.0023163 sec
Test "222" - RegAccess-->Direct R/W-->Dsy started
Test execution time 0.00032207 sec
Test "223" - RegAccess-->Direct R/W-->SBTL started
Test execution time 0.00013216 sec
Test "224" - RegAccess-->Direct R/W-->SGTL started
Test execution time 0.00030173 sec
Test "231" - RegAccess-->IIC-->Pogo_U1 started
Test execution time 0.0003662 sec
Test "241" - RegAccess-->PLL-->Serial started
Test execution time 9.2933e-05 sec
Test "251" - RegAccess-->Serial-->AtoD started
Test execution time 0.00019029 sec
Test "252" - RegAccess-->Serial-->U1093 started
Test execution time 2.6923e-05 sec
Test "253" - RegAccess-->Serial-->U1251 started
Test execution time 0.00019611 sec
Test "254" - RegAccess-->Serial-->U1500 started
Test execution time 0.00027024 sec
Test "311" - Acquisition-->Memory-->MemData started
Test execution time 5.0706 sec
Test "312" - Acquisition-->Memory-->MemAddr started
Test execution time 4.9468 sec
Test "313" - Acquisition-->Memory-->DataFormat started
Test execution time 2.4118 sec
Test "321" - Acquisition-->Acq Modes-->SubSample started
Test execution time 5.328 sec
Test "322" - Acquisition-->Acq Modes-->PeakDetect started
Test execution time 39.147 sec
Test "323" - Acquisition-->Acq Modes-->HiRes started
Test execution time 5.3412 sec
Test "331" - Acquisition-->Vertical-->50OhmOvld started
Test execution time 0.083661 sec
Test "332" - Acquisition-->Vertical-->ADC Connects started
Test execution time 7.0865 sec
Test "341" - Acquisition-->Interrupt-->Bit Tests started
Test execution time 4.932 sec
Test execution time 18.567 sec
Test "361" - Acquisition-->PLL-->Clock Freq started
Test execution time 0.44619 sec
Test "371" - Acquisition-->MemSpeed-->DemuxA started
Test execution time 3.9646 sec
Test "372" - Acquisition-->MemSpeed-->DemuxB started
Test execution time 3.9564 sec
Test "373" - Acquisition-->MemSpeed-->DemuxC started
Test execution time 3.9565 sec
Test "374" - Acquisition-->MemSpeed-->DemuxD started
Test "375" - Acquisition-->MemSpeed-->DemuxE started
Test execution time 3.9562 sec
Test "376" - Acquisition-->MemSpeed-->DemuxF started
Test execution time 3.9563 sec
Test "377" - Acquisition-->MemSpeed-->DemuxG started
Test "378" - Acquisition-->MemSpeed-->DemuxH started
Test execution time 3.9561 sec
Test "411" - Trigger-->Inputs-->Line started
Test execution time 0.074602 sec
Test "412" - Trigger-->Inputs-->Ch1 started
Test execution time 0.36551 sec
Test "413" - Trigger-->Inputs-->Ch2 started
Test execution time 0.35025 sec
Test "414" - Trigger-->Inputs-->Ch3 started
Test execution time 0.3504 sec
Test "415" - Trigger-->Inputs-->Ch4 started
Test execution time 0.35018 sec
Test "421" - Trigger-->Internals-->TimerA1 started
Test execution time 0.10015 sec
Test "422" - Trigger-->Internals-->TimerA2 started
Test execution time 0.10125 sec
Test "423" - Trigger-->Internals-->Btrig started
Test execution time 0.11813 sec
Test "424" - Trigger-->Internals-->BtrigEvents started
Test execution time 0.11882 sec
Test "425" - Trigger-->Internals-->TimeInterp started
Test execution time 9.3269e-06 sec
Test "426" - Trigger-->Internals-->Holdoff started
Test execution time 0.033314 sec
Test "511" - Misc-->Cal Integrity-->Factory Cal started
Test execution time 6.5385e-06 sec
Test "512" - Misc-->Cal Integrity-->SPC (run SPC) started
Test execution time 3.2212e-06 sec
Test "521" - Misc-->GPIB-->Interface started
Test execution time 0.00056856 sec
DIAGNOSTIC EXECUTION finished in 128.26 sec
--------------------------------------------------------------SPC ----------------------------------------------------------
0x381ae30 (SPC task): cc_loadV: CC_TRIGdcGain1b was 0; clipped
0x381ae30 (SPC task): ** M866CompCalibrator 1b failed -- ...wrote cal constant C
C_TRIGdcGain1b to 0.000000, failed
0x381ae30 (SPC task): cc_loadV: CC_TRIGdcGain2b was 0; clipped
0x381ae30 (SPC task): ** M866CompCalibrator 2b failed -- ...wrote cal constant C
C_TRIGdcGain2b to 0.000000, failed
0x381ae30 (SPC task): cc_loadV: CC_TRIGdcGain3b was 0; clipped
0x381ae30 (SPC task): ** M866CompCalibrator 3b failed -- ...wrote cal constant C
C_TRIGdcGain3b to 0.000000, failed
0x381ae30 (SPC task): cc_loadV: CC_TRIGdcGain4b was 0; clipped
0x381ae30 (SPC task): ** M866CompCalibrator 4b failed -- ...wrote cal constant C
C_TRIGdcGain4b to 0.000000, failed
total cal time 4.40 minutes
