ok,
some additional information:
1. No matter if I set the boot parameters again, it does not start a second time, with battery connected.
2. But I can start the scope without battery and set the boot params every start by hand.
I haved checked the soldering of the NVRAM several times, without any trouble. If I interrupt the boot process the printed out boot params are always correct. That tells me, that the battery and NVRAM are working fine in general.
But the boot log of vxWorks (the first and successful start) tells a lot of checksum errors.
If there is no solution, I will disconnect the NVRAM battery permanently and connect an arduino to the serial, that sends the boot settings every startup.
The self diagnostic of the scope runs without any issue.
omPost: DRAM Cell test passed.
romPost: Disabling data Cache...
romPost: Data cache disabled.
romPost: Disabling instruction cache...
romPost: Instruction cache disabled.
romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF...
romPost: Writing address to each *address...
romPost: Reading address from each *address...
romPost: DRAM march test passed...
romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON...
romPost: Enabling data cache...
romPost: Data cache enabled.
romPost: Enabling instruction cache...
romPost: Instruction cache enabled.
romPost: PERFORMING DRAM WALKING-ONE TEST...
romPost: DRAM Walking-one test passed.
romPost: PERFORMING NV-MEMORY WALKING-ONE TEST...
romPost: NV-MEMORY Walking-one test passed.
romPost: POWER-UP DIAGNOSTIC COMPLETE.
Hel
VxWorks System Boot
Copyright 1984-1996 Wind River Systems, Inc.
CPU: Tektronix HPP - PowerPC 740
Version: 5.3.1
BSP version: 1.0.1
Creation date: Apr 20 2000, 08:34:24
Press any key to stop auto-boot...
7
6
c
[VxWorks Boot]:
[VxWorks Boot]: c
[VxWorks Boot]:
boot device : sm
processor number : 0
host name : host
file name : c:\vxBoot\vxWorks.st
inet on ethernet (e) : 192.168.0.2:ffffff00
inet on backplane (b): 192.168.0.2:ffffff00
host inet (h) : 192.168.0.1
gateway inet (g) : 192.168.0.2
user (u) : anonymous
ftp password (pw) : anonymous
flags (f) : 0x1000
target name (tn) : target
startup script (s) : c:\vxBoot\topScript.hw
other (o) : nvfs=0x1000
Initializing backplane net with anchor at 0x1e80000... done.
Backplane anchor at 0x1e80000... Attaching network interface sm0... done
done.
Attaching network interface lo0... done.
PC1 dio device driver installed
Attaching DIO client... done.
Loading c:\vxBoot\vxWorks.st...1773344
Starting at 0x200000...
Initializing backplane net with anchor at 0x1de0000... done.
Backplane anchor at 0x1de0000... Attaching network interface sm0... done
done.
Adding 6003 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
CPU: Tektronix HPP - PowerPC 740. Processor #0.
Memory Size: 0x2000000. BSP version 1.0.3.0.
WDB: Ready.
usrNvFsInit: NAME=/nvram BASE=0xfd0ff100 BPB=512 BPT=8 NB=8 BO=0
nvfs: WARNING: Creati0xng new NVRAM file 1fffe08system
tcsTableUnpack: checksum failed on buffer
tcsTableLoadFromNVRAM: tcsTableUnpack failed
(tRootTask): memPartAlloc: block too big - 322897788 in partition 0x3375cc.
KERNEL: THERMAL CONTROL INITIATED
Executing startup script c:\vxBoot\topScript.hw ...
dbFsIoctl: invalid code 3
################### topScript starts ###############################
cd "dbfs:c:/vxBoot"
value = 0 = 0x0
ld < TekScope.o
value = 30931936 = 0x1d7fbe0
ld < TekScopeSM.o
value = 30947136 = 0x1d83740
pDbDev = ramDevCreate(0, 512, 1024, 1024, 0)
new symbol "pDbDev" added to symbol table.
pDbDev = 0x1d839e0: value = 30947840 = 0x1d83a00 = pDbDev + 0x20
pDBfs = dosFsMkfs("/db", pDbDev)
new symbol "pDBfs" added to symbol table.
pDBfs = 0x1d83580: value = 30947584 = 0x1d83900 = pDBfs + 0x380
copy ("TekScope.DBF", "/db/TekScope.DBF")
value = 0 = 0x0
overrideFPdefaults()
value = 0 = 0x0
measurePPCtimebase
value = 0 = 0x0
registerMemPartitionSizes ( 0x00000000 )
value = 0 = 0x0
semInitForQueueCheckLogMsg
value = 30946528 = 0x1d834e0
initSysWaiter()
value = 0 = 0x0
raxInit
value = 0 = 0x0
paiInit
done
value = 22542592 = 0x157f900 = PaiBaseRegisterTable + 0x948
verifyAcqBoardID
value = 0 = 0x0
updateAcqProcFirmware("dbfs:c:/vxBoot/acqProc.hex")
0x1d8a060 (tShell): 1340 bytes successfully verified.
AVR processor FLASH contents match file dbfs:c:/vxBoot/acqProc.hex - no programming needed.
value = 0 = 0x0
cd "pc:"
value = 0 = 0x0
raxInitializeDevices
done
0x1d8a060 (tShell): (Re)starting Acq Processor
value = 30973488 = 0x1d89e30
excHookAdd(stopStressForException)
value = 22295856 = 0x1543530 = stopStressForException
dsyInit
value = 29147656 = 0x1bcc208
dsyWPApplyNextRegs
value = 22532472 = 0x157d178 = DsyRegisterTable + 0xab0
# remove '#' from next line to set powerup scope state to factory default:
# NvramClearDb = 1
nvram_initFileSys
0x1d8a060 (tShell): >> Restoring exisiting filesystem in NVRAM...
0x1d8a060 (tShell): >> bd_bytesPerBlk 512 / bd_nBlocks 254 / bd_blksPerTrack 254, pNvRamDiskVolDesc 0x0
0x1d8a060 (tShell): >> Creating new /nvram device...
0x1d8a060 (tShell): >> iosDevFind Status 0x1d9a520
0x1d8a060 (tShell): >> Creating filesystem in NVRAM...
value = -49409789 = 0xfd0e1103 = pDbDev + 0xfb35d723
TmgrInit("/db")
0x1d8a060 (tShell): NO BACKUP SERIAL NUMBER FOUND, RESTORING VALUE FROM DISK...
0x1d8a060 (tShell): >> Reading config values from files on hard disk....
0x1d8a060 (tShell): NO BACKUP OPTION KEY FOUND, RESTORING VALUE FROM DISK...
value = 0 = 0x0
PhxProxyInit
value = 27785888 = 0x1a7faa0 = invertY + 0x250
rtlInit
value = 0 = 0x0
sysExtMemAddToPool memSysPartId,0x02000000,0x06000000
value = 0 = 0x0
hwAccount_init
sysEnetAddrGet: 66:c5:23:fa:77:09
value = 0 = 0x0
GpibInit
value = 0 = 0x0
wfmMemInit(1)
value = 47693536 = 0x2d7bee0
vertInstall
value = 47687652 = 0x2d7a7e4
calConStatus = cc_init(2)
0x1d8a060 (tShell): Reading 280 bytes of service cal data from EEPROM[0] into 0x2d7a6c0
0x1d8a060 (tShell): x24165_read succeeded
0x1d8a060 (tShell): Reading 66 bytes of service cal data from EEPROM[280] into 0x2d7a780
0x1d8a060 (tShell): extd chksum failed, stored = 0xffffffff calc = 0x28d5a0ee
0x1d8a060 (tShell): cc_init: extended bank17 chksum failed, NOT reset to factory
0x1d8a060 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/0
0x1d8a060 (tShell): cc_init: bank 0 chksum failed, NOT reset to factory
0x1d8a060 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/1
0x1d8a060 (tShell): cc_init: bank 1 chksum failed, NOT reset to factory
0x1d8a060 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/2
0x1d8a060 (tShellcalConStatus): cc_init: bank = 2 chksum failed, NOT reset to factory
0x0x1d8a06017c8f10 (tShell): : value = cc_restoreBank: can't open file 164335C:/vxBoot/calCons/ = 0x3
0x1d8a060281ef (tShell): cc_init: bank
3 chksum failed, NOT reset to factory
0x1d8a060 updateTrigCal (
tShell): cc_restoreBank: can't open file value = C:/vxBoot/calCons/05
0x1d8a060 = 0x (tShell): cc_init: bank 05 chksum failed, NOT reset to factory
0x1d8a060 (
tShell): cc_restoreBank: can't open file MathMeasCreaC:/vxBoot/calCons/te6TheMathandMeasureme
ntLibraries0x1d8a060
(tShell): cc_init: bank 6 chksum failed, NOT reset to factory
0x1d8a060 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/7
0x1d8a060 (tShell): cc_init: bank 7 chksum failed, NOT reset to factory
0x1d8a060 (tShell): cc_restoreBank: can't open file C:/vxBoot/calCons/8
value = 0x1d8a060 (tShell47514752): cc_init: bank = 0x8 chksum failed, NOT reset to factory
2d50480x01d8a060 (tShell):
cc_restoreBank: can't open file inC:/vxBoot/calCons/it15AcqMapper
0x1d8a060
(tShell): cc_init: bank value = 15 chksum failed, NOT reset to factory
00x1d8a060 = 0x (tShell): initAcqMapper: Enter
0
trigMapInit
value = 0 = 0x0
dsyMapInit
value = 0 = 0x0
mathMapperInit
value = 0 = 0x0
utilMapInit
value = 47512096 = 0x2d4fa20
TmgrHookup
value = 0 = 0x0
PhxProxyHookup
value = 0 = 0x0
hookupAcqMapper
value = 24911840 = 0x17c1fe0 = AcqMapperRtlDataList
MathMeasMapHookup
value = 30973336 = 0x1d89d98
dsyMapHookup
value = 30973432 = 0x1d89df8
utilMapHookup
value = 30973456 = 0x1d89e10
rtlHookup
value = 0 = 0x0
horizMapHookup
value = 30973424 = 0x1d89df0
fastFrameMapHookup
value = 30973440 = 0x1d89e00
trigMapHookup
value = 30973448 = 0x1d89e08
vertMapHookup
spcMapHookup
autosetMapHookup
value = 30973480 = 0x1d89e28
timeSyncMapHookup
value = 30973472 = 0x1d89e20
auxTrigMapHookup
dpoMapHookup
TmgrStartup
value = 47021648 = 0x2cd7e50
PhxProxyStartup
value = 46971104 = 0x2ccb8e0
taskDelay(2)
value = 0 = 0x0
gpibHwInitC
value = 0 = 0x0
gpibTaskSpawn
value = 46858832 = 0x2cb0250
gpibIoInit "/dbios/DBIO005","/dbios/DBIO006"
value = 46828304 = 0x2ca8b10
enablePowerupDiags = 0
enablePowerupDiags = 0x17a028c: value = 0 = 0x0
runPowerupDiags
0x2d19b20 (tmgr): >> Commit opt_currOptKey string[64] <4YXSS-LFHHJ-TZUNS-ABI8P>
0x2d19b20 (tmgr): >> Writing new checksum 0x69e0 to nvram....
dipSwitch = 0x0, enablePowerupDiags = 0, puMode=0
CalDiagPowerUpDiagsEnabled = 0
!! SKIPPING POWERUP DIAGNOSTICS !!
done
value = 22552812 = 0x15820ec = SoftSwitchesRegisterTable + 0x48
rtlStartup
value = 0 = 0x0
tsComp
value = 0 = 0x0
################### topScript ends ###############################
Done executing startup script c:\vxBoot\topScript.hw
KERNEL: RUNNING TIME SLICED AT 10 TICKS PER SLICE!
