Haha if it wasn't in the corner of the room behind my stereo speakers I probably wouldn't mind slapping it!
When I say the switch won't turn it on, I mean that if I turn on the power manually at the power switch which is either Always on or Auto sense. Even when I get it to turn green meaning it's in active mode (before it will eventually go to sleep in auto-sense) and the subwoofer signal is actively being sent, I get no sound.
If I slap the top of the subwoofer in any area with a decent amount of force, harder than you would spank your dog. The sub always kicks on immediately, no matter if in auto-sense or in "on" mode. Eventually after so much time of the sub working it will kick back off and require another slap before it will ever work. I also assume something is being shaken enough that it is messing with the signal reaching the line in sensor.
I am using a very nice Canare LV-61S 75 Ohm subwoofer cable, so it's not the cable (and I tried three of them). I know the signal from my Yamaha RX-V863 is fine since it is working after the slap haha.
Just wanted to elaborate a little more on the symptoms I am seeing. I will definitely open her up and take a look at anything which is suspect.
Might make a good article for my website:
zosoncsu.com !!
