hello my situation is i bought a TDS7404B without HDD.
and that scope had a D845 board which has no SATA connection and just 2 dimm slot for max 2GB, if i remember well
i want to go to win7 with 4 gb. or may a fast booting scope
and i want a SSD direct on the motherboard for highest boot speed.
so i decided to switch to the D865 because it is used in many scopes. So must be a good choice which is in my needs.
but one thing what i dicovered is. when i took both D845 and D865 separate on my bench is. the D845 boots up native. where MY D865 doesnt .
i thought my board was not ok because i saw you , in your repair video boot up the D865 in native mode ( Cpu/PSU/mem) connected to onboard video.
few days later i got a dead D865 which i fixed ! guess what this board has the same behaviour then my first D865. really strange when i look at your video 3:19 again startup behaviour differs.
when i put in a PCI card both boards wake up when i power them up. so the PCI card must be installed te wake them up.
while your board boots native. so from my guess the bios default must be different or greyout or any thing.
both my boards work 100% fine but needs the extra card to wakeup for boot. really weird. while your board doesnt.
is this a bios difference. ??
i cannot / won t install an extra card just for booting.
i want to discover the difference.
i hope this clears things up.
so i hope somebody is willing to export his complete bios from the TDS5054B to see if that fixes my boot problem.
strange but... it must be i guess...
maybe an other question does your board from the internet boot up native ?? if yes what exact cpu do you have installed. maybe thats the problem, i tried a 3.06Ghz 512kb and a 3.06Ghz 1Mb (prescot) Total different behaviour
