I purchased a second hand Unoahm EP 2500 field meter. It is in working condition and was overall a nice deal and cool add-on to my collection.
I cleaned it, stiched the softbag and was pretty happy, when I noticed that suddenly the CRT brightness increased. I cannot specify the exact moment.
Anyway, even with the brightness toggled (per software) to minimum value, the screen is too bright.
I opened the case (once again) and toggled the miniature poti, but none allows additional brightness control.
The field meter can be operated in three modes:
- just by 12V Ni-MH battery, which is not a real option, because the battery is virtually dead and the image on the CRT screen does not get to its whole width, probably due to lack of voltage?
- just connected to mains through a 16V DC transformer and battery removed - image is too bright
- connected to mains and charging the battery - image is too bright
On the power input, a sticker says 12-18V operation, 15-18V charging. 12V is currently not enough to drive the CRT as it should, unless I reconfigure the three poti, but then the image gets screwed up when I attach the power source.
I tried feeding 12-16V on both the power input and battery connector and with a voltage <15V the image is a little darker, but not filling up horizontally, >15V it fills the CRT horizontally, but is too bright.
From what I read, the cause could be the 250V capacitor on the CRT board, but visually it looks OK. Actually all capacitors look fine.
I know about the dangers and risks regarding handling a CRT and despite this one being just 4.5", I do have respect of the charge contained in the tube and capacitor. I have discharged a CRT a couple of times in the past, also of a field meter (I exchanged the CRT tubes between two field meter).
My questions:
Where should I start to find the culprit?
What is likely to be the cause?
Other issues of this field meter:
1) CRT -> too bright
2) Memory operation like storing channel or logger data will produce a timeout error of the eeprom/flash. I ordered new ICs, as I want to upgrade the firmware, but the uploader software requires a key code based on the serial number, which I don't have.
3) Power source has a bad contact somewhere in the cable - needs to be cut and resoldered to the connector: It *may* have been due to a few reboots caused by sudden power loss that the CRT suddenly became to bright. The power source is working fine, though, as I measured it and used a programmel power source, too.
As it is, the device is fully functional and the screen is usable. It just annoys me, because I know it should be a much darker picture.
Mind me: the whole fun is this cleaning, repairing, upgrading firmware, finding all files, etc. Once all of this is done, the field meter goes to the cupboard where all the otehr field meter are stored... -->TEA thread calling... For regular use I have modern field meter which are light years ahead of this one.
Regards,
Vitor
