Hi guys, could you share tips on how to de-solder components of board which is soldered on both sides. Mainly I have trouble with de-soldering IC's rather than components. I tried solder suckers, wicks -what only worked for me is heating and pulling but that sometimes causes the solder pads to lift or the trace to lift.
What temperature would you recommend having the iron set at?
Thanks in advance for the help.
