mosfets don't like overvoltage, irs2113 has mosfets, case closed. you said yourself you heard fluctuations, added with some limit pcb design flaw and some limit capacitor VCC side and trace inductance, that's it. making a rock-solid power stage is not easy, i saw 3000 amp igbt's exploding from some mistakes like this. in the field, we mumble 2 minutes than replace the drivers and the filtering electrolytic caps (newer development, we verify 100n/10n smaaaaall and possible cracked smd caps) adn wait another cycle of voltage fluctuation mains side or the caps to die again. they called it now planned obsolescence
