You must disconnect the SW_POWER(POW/on/off) wire from the motherboard and leave it in the air. You should have 12V and 114V(for inverter) all the time if the power source is good. The wire is found on the power connector that feeds the motherboard, I think CN201, no. 2. if I'm not mistaken.
