Author Topic: DR TALBOTS INFARED THERMOMETER  (Read 708 times)
Offline m3vuvTopic starter
« on: November 28, 2021, 03:23:01 pm »
Hi all i have a doctor .talbots ir thermometer,i brought it cheap as not working,it lights up and seems to measure ok,it has what looks like a mirrored concave with some sort of sensor behind it,mounted above the mirrored reflector looks like a lased diode,if its a laser it cant be seen to work,i got this to check a faulty ebike battery to look for different temp 18650 cells,i assume it has a red laser diode to aim it?,any clues welcome.TIA
Offline TheMG
Re: DR TALBOTS INFARED THERMOMETER
« Reply #1 on: November 29, 2021, 02:28:51 pm »
Yes the purpose of the laser is only to aid in aiming.
« Reply #2 on: November 30, 2021, 06:37:33 am »
well in that case the laser part of mine is dead,as nothing lights up at the front of the unit,just the lcd display at the rear !
