(ExEE longwinded warning)
Summary: Does anyone know about Plasma cutters and can explain why four out of 12 wires in a cable assy failed without visible damage to the insulation?
Had a new experience working with a company formed by some former co-workers at the excavator plant. They do metal fabrication and welding. My former boss called me and asked if I would look at their plasma cutter lead. At the time I knew nothing about plasma cutters, and I still find it difficult to wade through the marketing wank and get real information.
He called me when an interlock stopped working. When a part of the torch is installed, it closes a switch to enable operation. That wire was open. After checking both connectors (hoping for an easy solution) we realized the long (6-12 feet, or 1-3 meters) cable assy had a broken wire in it. This was an otherwise ordinary multi conductor cable (about 12 22 AWG, .3 sq mm) with an air hose inside it. I cut into the cable and got lucky - I found the bad spot in the interlock wire.
I've seen burned wires in cable assys and harnesses before - usually the insulation melts and or burns and it's visibly damaged. This wire looked perfect, but for about 1-2 mm, there was no copper inside the wire. It was a plastic tube. I cut and stripped the end for soldering in a new wire, and did a quick check to the other end to be sure there were no other breaks. "While I'm there..." I decided to check the other wires. There are 7 wires spliced together at the torch that go to 7 connector terminals at the other end. Three of them were broken in the same way. (Fortunately, in the same area that I had already cut open.) I replaced these as well. The guy using it says it cuts better than it ever has, leading me to believe that the wires failed one after the other, slowly.
I did learn that plasma cutters operate at about 100-200 volts and about 30 amperes. The seven 22 AWG wires seem to be adequate for that. I just can't figure out what happened and why, and if it's doomed to happen again. Can anyone offer any insight?
My thought is that if it fails again, I'll run a 12 or 10 AWG (3-5 sq mm) wire alongside the cable, if it is not objectionable to the operator, and consider if the unused connector terminal positions can be used to add more parallel wires going into the machine.
OF course, I'm hindered by not knowing the model of the machine. I'll have to ask.
EDIT: It's a Miller 875 rated for 60 Amperes at 140V, but max open circuit voltage is 400V. Duty cycle is supposed to be 40 percent at 60 amperes, but we know how people are when there's a job that needs to be done. I saw no mention is made of the machine failing to operate if duty cycle is exceeded or if the unit overheats.
manual with wiring diagram, if anyone is interested. (open wire 15 stopped it from working. I see the diagram only shows 5 operating current wires (1-5) two more were added, spliced together using only one connector position.) This indicates they know they have a problem and have made at least one revision to try to stop it.
http://eagleplasma.com/cutters/manual-miller875-autoline.pdf
