I was messing with an old fluorescent tube fixture and the electromagnetic ballast got loose and pulled from the cables connected to it but due to the very strong gravitational force we have in this area the cables pulled the screw terminal off and the tiny wires from the coil broke off leaving only a few mm exposed and accessible. If they were copper this would not be a problem as I could just solder a copper whisker but, unfortunately, the ballast winding is aluminum or aluminium, one of the two, so no soldering.
Using screw terminals is impossible. Twisting is impossible.
I can connect to them, barely, using those terminals with a tiny hook at the end but this is unwieldy and not very secure.
What would be the best way to connect to these AL wires?
I do not need any suggestions to get a new electronic ballast, etc. I know all the alternatives very well. This is just for the fun of it.
And, just to digress a bit, and totally unrelated, I have a box full of wall wart SMPS which are not working. I know full well they are not worth repairing as they are so cheap to buy, but yesterday afternoon I repaired three of them just by replacing input or output caps and I felt it was quite an acomplishment to get three out of junk box and into the "available for use" box.
