Author Topic: Weird problem with modern kitchen hood  (Read 782 times)
Offline RiRaRiTopic starter
  • Country: hr
« on: September 28, 2023, 10:09:14 pm »
Hello. My 5 years old kitchen hood suddenly stopped working, completely. There are two PCBs inside. Main one with transformer and relays. And second one with touch-sensitive buttons. On the power supply board i tested everything i could: capacitor, thermistor, relays, graetz connection etc. and it all measures good. Second one is full of small SMD components which i can not fully test. Connection between two PCBs is tested and fully working and connecting as it should.
Things that i noticed:
When i connect touch panel to power supply PCB, transformer starts to heat very much (can not be hold with hands), and voltage drops from 17.5V to 2.9V. Transformer is rated to 9V. Without any load and only connected to main PCB without touch panel/fan/lights measures 17.5V.
I did test with programmable DC PSU which i connected after graetz connection and when touch panel is disconected it measures no current but when i connect touch panel it reaches limit (draws more then 3A current). Here is video of my test: https://youtube.com/shorts/r7lAetzZ0N4
When i connect touch panel half-way and at angle LEDs starts to work, and at other angle fan is working but touch sensitive switches does not work.
When i power up switch PCB with my adjustable PSU it is short.
PS All connections and wire between touch panel and main panel are tested and they are good, so it is not bad plug.
Also, 4 of 6 (total) pins on switch panel are fully connected to each other.
Here are photos of both PCB
Thanks for your help.
« Last Edit: September 29, 2023, 12:45:27 am by RiRaRi »
  • Country: hr
Re: Weird problem with modern kitchen hood
« Reply #1 on: September 28, 2023, 10:09:47 pm »
Power supply panel
  • Country: hr
« Reply #2 on: September 29, 2023, 04:52:22 pm »
Can anyone help?
Offline blauerscharik
« Reply #3 on: September 29, 2023, 05:56:15 pm »
With 3A shouldn't you be able to see what gets hot? With a thermal camera or some alcohol or touching?
  • Country: hr
« Reply #4 on: September 29, 2023, 10:53:28 pm »
I dont have thermal camera. How to test with IPA?
Offline fzabkar
« Reply #5 on: September 29, 2023, 11:32:15 pm »
U1 appears to be a linear regulator. If so, check the resistance between Ground and each of Vin and Vout.
Can you identify the markings on all your ICs?
« Reply #6 on: September 30, 2023, 07:48:33 am »
If a component is shorted then you would be able to touch the board and find the general area where it is getting warm/hot. And then I would put a couple droplets of IPA in that area and see where it evaporates fastest and that would be your shorted component.
