Author Topic: Sourcing a replacement transformer, LCD TV repair.  (Read 11402 times)
Offline wraper
  • Country: lv
Re: Sourcing a replacement transformer, LCD TV repair.
« Reply #50 on: September 25, 2018, 02:43:51 pm »
putting the ZD604 and ZD605 back to their original position I find on one side of the r609 I have 13v and on the other side 0.9v
This completely contradicts with:
before R630 I have 78v, between R630 and R631 I have 38v, between R631 and R609 I have 38mv
Offline wraper
  • Country: lv
« Reply #51 on: September 25, 2018, 02:45:16 pm »
Did you check ZD605 BTW, isn't it shorted by chance?
Offline wraper
  • Country: lv
« Reply #52 on: September 25, 2018, 03:15:07 pm »
Also write part number of IC601, I don't know what it is.
Offline boba3
« Reply #53 on: September 25, 2018, 03:18:20 pm »
I had to get out of work. I will resume tomorrow. Thank you very much for your information and your patience. We'll talk tomorrow. good day
Offline boba3
« Reply #54 on: September 25, 2018, 03:21:40 pm »
Ic601=A6069H
Offline boba3
« Reply #55 on: September 25, 2018, 03:28:45 pm »
In R609 there is written 625
Offline wraper
  • Country: lv
« Reply #56 on: September 25, 2018, 04:04:33 pm »
Ic601=A6069H
I checked the datasheet. It's strange they placed R609 at all. Seems it has 6.2M resistance. This IC actually takes startup current from pins 7,8 and pin 2 is for voltage detection only. Thus placement of R609 is weird but as it has a very high resistance it basically does nothing. As you said there was 38mV on pin 2 when IC was present, I assume that IC is either faulty ir you got counterfeit with something else inside. Where you bought the replacement IC?
http://www.semicon.sanken-ele.co.jp/sk_content/str-a606xh_ds_en.pdf
« Last Edit: September 25, 2018, 07:03:04 pm by wraper »
Offline boba3
« Reply #57 on: September 25, 2018, 04:51:29 pm »
Tomorrow I replace the components that I had removed each of their original poto and recheck. Honestly Ic601 after being exploded did not read what was written. It read only A .... H Then on the web I found it was A6069H. Actually I do not know if it's correct
Offline wraper
  • Country: lv
« Reply #58 on: September 25, 2018, 10:32:49 pm »
Try measuring resistance between pin 2 and 3 of the IC.
Offline boba3
« Reply #59 on: September 26, 2018, 06:16:46 am »
Good morning, I checked the schematic of the power card you sent me and it corresponds to my card. I put all the components back to their initial position. now without ic601 I have between GND and before R609 13v, between GND and after R609 i have 0.9v. I checked the schematic of the A6069H and it seems to me that the GND is the pin 3, and the Vcc is the pin5. is it correct? between pin 2 and pin 3 I have about 1Mohm. between GND and pin 7/8 of IC 601 of the board I have 320v
Offline boba3
« Reply #60 on: September 26, 2018, 10:40:25 am »
I have 0.9 without ic601 installed, and I have 38mv with ic 601 installed
Offline wraper
  • Country: lv
« Reply #61 on: September 26, 2018, 11:35:05 am »
it's a bit confusing what you wrote in last 2 messages.
What do you have before R609 with IC installed?
Offline boba3
« Reply #62 on: September 26, 2018, 12:10:09 pm »
with ic installed, before R609 i have 38mv
Offline wraper
  • Country: lv
« Reply #63 on: September 26, 2018, 12:23:37 pm »
Pin 2 is input, so it should not pull voltage down this lot. It has a 6.4V zener diode on it so it what it should be limited to. 38mV certainly seems as indication that IC is either faulty or counterfeit.
Offline boba3
« Reply #64 on: September 26, 2018, 12:38:14 pm »
ok, I will get another one. if this has burned up there is still something wrong with this card? I removed ic and in pin 2 I have 13v but in the 5 i continue to have 0.9v. Is it normal?
Offline wraper
  • Country: lv
« Reply #65 on: September 26, 2018, 01:32:34 pm »
Yes, it's normal. Unless there is something wrong with parts connected to pins 7,8, it should not fail. And if it fails, most likely it will blow up. Hence I suspect counterfeit, there are plenty at shady sources.
Offline boba3
« Reply #66 on: September 26, 2018, 02:11:47 pm »
can you advise me where to buy it?
Offline boba3
« Reply #67 on: September 27, 2018, 02:24:48 pm »
good morning, when I get ic new, can I check it somehow before installing it?
Offline wraper
  • Country: lv
« Reply #68 on: September 27, 2018, 03:25:34 pm »
just solder it in
Offline boba3
« Reply #69 on: September 28, 2018, 05:58:27 pm »
hi, I replaced ic. now I have 5v, but there is a problem in the PE0982 tab V28A001292A1. because when I connect it I'm 5v volts to 0. Is there a short circuit in the part of 5v. Is there a datascheet for this card?
Offline boba3
« Reply #70 on: October 04, 2018, 06:44:50 pm »
hello,
the board at the desk, in addition to having 5 volts must have other power supplies?
