Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
HARMAN KARDON HKTS220SUB/230 humming noise
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HARMAN KARDON HKTS220SUB/230 humming noise (Read 994 times)
Charlie86
Regular Contributor
Country:
on:
March 22, 2021, 05:35:18 pm »
I have a problem with in HARMAN KARDON HKTS220SUB / 230. It started humming even if it is not connected to any source. The sound is very similar to that in the video.
https://youtu.be/CkMOZc1W9Jw
I found a service manual but unfortunately I can't help myself with it.
https://elektrotanya.com/harman_kardon_hkts_220.pdf/download.html#dl
I also tried replacing three capacitors and a resistor from link below, but Subwoffer is still humming.
https://www.ebay.com/itm/Reparatur-Set-V2-0-fuer-das-Netzteil-HKTS210SUB-230-Harman-Kardon-13-Teile-/363266392654
Any idea, how to repair it?
Logged
cdev
Super Contributor
Country:
Re: HARMAN KARDON HKTS220SUB/230 humming noise
Reply #1 on:
March 22, 2021, 06:13:23 pm »
Is it the power transformer? If so, maybe you can replenish the varnish and dry it out in an oven. Search on transformer hum. Sometimes a vacuum is also used to suck out the air so the the varnish penetrates deeper.
Logged
Charlie86
Regular Contributor
Country:
Reply #2 on:
March 22, 2021, 06:18:22 pm »
It uses switching power supply. Humming is comeing directly from speaker. Speaker vibrates.
Logged
cdev
Super Contributor
Country:
Reply #3 on:
March 22, 2021, 07:13:04 pm »
You should check the capacitors for bulging or leaking, and/or high ESR. Loss of the filter function from caps drying out will make such a hum. Nine times out of ten, this is whats wrong, unless the receiver is fairly new.
Last Edit: March 22, 2021, 07:15:58 pm by cdev
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
