Author Topic: Nixie tube driver transistor substitute.  (Read 1394 times)
Offline institchesTopic starter
« on: September 06, 2018, 11:15:25 pm »
I am repairing a 1969 Toshiba nixie tube calculator and have identified a dead power transistor which was the cause of a dead nixie.
I'm looking for a replacement / substitute but not having much luck.
Does anyone know if there is a modern equivalent available for this transistor? https://datasheetspdf.com/pdf-file/854648/Sanyo/A429/1
Or is there another way I could drive the nixie with modern parts? I don't have any schematics for the calculator unfortunately.
Thanks in advance.
Online oPossum
Re: Nixie tube driver transistor substitute.
« Reply #1 on: September 06, 2018, 11:43:41 pm »
MPSA92 will probably work as a substitute for the 2SA429
MPSA42 is it's NPN compliment and is commonly used with nixie tubes.
« Last Edit: September 07, 2018, 03:27:47 am by oPossum »
« Reply #2 on: September 07, 2018, 12:15:27 am »
Thank you very much.
Offline wilfred
« Reply #3 on: September 07, 2018, 12:23:20 am »
Offline ArthurDent
« Reply #4 on: September 07, 2018, 03:24:25 am »
