I got everything back together and working but with one issue. Without a load, the output transformer is buzzing. Without a load, the buzzing get louder as the voltage is increased. Under load it is quiet. While is was buzzing I tried to press on the transformer winding and the core but there was no change. As I said, there is no problem under load. Could there still be a problem that is causing the transformer to buzz without a load?
