Author Topic: Identifying QFN16 3x3 mm buck DC-DC Li-ion charger  (Read 932 times)
Offline martonmiklosTopic starter
  • Country: hu
    • Blog
« on: September 19, 2023, 08:49:13 pm »
Hi folks,
I am trying to repair a Braun Silk Epil 9 series motherboard.
The on board single cell Li-ion DCDC charger IC looks to be defective.
It runs from 12V, and when it starts charging it brings my bench PSU CC.
I have drawn a reverse engineered symbol for it, does anyone could identify it?
I used up all my google fu with qfn16 li ion and dcdc keywords, but I have not found any pinout compatible one.
The markings on the IC:
4561
1909
32144
« Last Edit: September 19, 2023, 09:13:35 pm by martonmiklos »
Offline fzabkar
Re: Identifying QFN16 3x3 mm buck DC-DC Li-ion charger
« Reply #1 on: September 20, 2023, 11:17:47 pm »
Perhaps if we could identify the other ICs, this may help us to determine the manufacturer, or at least the country of manufacture.
BTW, the second line appears to be a YYWW (year/week) date code. I have confirmed this by examining other PCBs.
« Last Edit: September 20, 2023, 11:19:35 pm by fzabkar »
The following users thanked this post: martonmiklos
Offline thm_w
  • Non-expert
« Reply #2 on: September 21, 2023, 12:08:27 am »
Does the output go directly to a single lithium cell? Or does it pass via another IC.
If there is space bodge in a TP5100 or similar charging module. Or convert to USB and use TP4056.
  • Country: hu
    • Blog
« Reply #3 on: September 25, 2023, 08:11:40 pm »
There are not much identifiable parts on the board other than the MCU (made by Cypress).
There are two BC847BS on the board the rest of the IC-s/transistors are not identifiable.  :-\
  • Country: hu
    • Blog
« Reply #4 on: September 25, 2023, 08:16:01 pm »
The output is connected to the li-ion cell through a fuse.
There are some status reporting wired to the MCU which needs to be reverse engineered.
Before the IC removal the device indicated charging (with a LED blink code) without charger connected (the device cannot be operated during charging). When I shorted out the charging input pins it got functional. After the IC removal I cannot turn it on.
Offline fzabkar
« Reply #5 on: September 25, 2023, 08:19:59 pm »
