hi, seems easily repairable, being a beginner try to remove all 220V parts (I mean the caps/ptc from the burnt area) and check them, you may got a trace gone in magic smoke, you may miss it. try to replace the caps if dead
of course clean with some acetone or alcohol the pcb on bottom side at least
