Blurry, low-resolution images make it very difficult to provide help. Take clear photos, front and back, using bright, soft lighting that avoids shadows. And then don’t shrink them to 640x480, do something reasonable like 1200x900 to 2400x1800.
We can’t identify threads by ID, and even if we could, it’s unlikely that “137” is correct, in that this forum has nearly 200,000 threads, and 137 would have to be extremely old. Just post the URL if you want to refer to another thread!
When you say “all capacitors”, do you mean just the electrolytic caps, or all the film and ceramic caps as well?
I assume that by “shortcut”, you mean “short circuit” (often abbreviated to just “short”)? (A shortcut is an easier or faster way to get somewhere.)
