Author Topic: Name that part  (Read 406 times)
Offline jheatacTopic starter
Name that part
« on: August 03, 2024, 08:49:39 pm »
Can someone tell me what these are?
I removed them frome something I scrapped but I don't remember what. At first glance they look luke a light bulb but there is no filament. I also know there was no need for light at their location on the board.
Marked 102 and 08E
Thanks
Offline fzabkar
Re: Name that part
« Reply #1 on: August 03, 2024, 09:17:20 pm »
The following users thanked this post: boB
Offline Andy Watson
Re: Name that part
« Reply #2 on: August 04, 2024, 12:02:55 am »
They look very well made for "lamps". Also, ...
... there was no need for light at their location on the board.
I think they are most likely some form of gas-discharge (possibly neon) voltage stabliser/supressor.
Re: Name that part
« Reply #3 on: August 04, 2024, 12:51:23 am »
I don't remember 100%, but I am thinking they are off the power supply board for a relatively newer (1080 era) sony projection TV.
I really don't think they were for an indicator because they were in the middle of other components just sitting on the board.
Neon bulbs need a driver/ballast to get them started, don't they?
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
Re: Name that part
« Reply #4 on: August 04, 2024, 01:02:41 am »
No. Neon will conduct at 90 volts if I remember right. I think older fluorescent starters had neon elements and also some thermal contacts. If you are old enough, you will remember the two flashes of a fluorescent lamp before it was on.
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
