Your 5 pins transistor is the smps suply driver controller, I think your amplifier ic is under the pc board, you have an metal bracket with two holding screws near the kt-3150 pcb markings
DEDUCTION : You see an shielded audio cable coming from the preamp board ... you see 220 marked inductors, you see you speaker cable near them ...
