Author Topic: Fluke 45, optocoupler replacement  (Read 1368 times)
Offline vidiTopic starter
  • Country: sk
« on: August 29, 2018, 08:22:49 pm »
Hi folks,
I'm trying to repair Fluke 45 for a friend and one of the issues is that optocoupler U3 is half dead (stops optocoupling at temperature 30 C). I wonder if anyone here did a replacement and if - what component has been used instead, since I'm not able to find any specs. What I know about the old one: it is phototransistor optocoupler with forward threshold voltage 1.06V.
Thanks.
BTW, it seems to be the cause of ERROR 8 (Analog Measurement Processor A1U1 dead) and ERROR 9 (Measurement self-check failed).
« Last Edit: August 29, 2018, 08:32:20 pm by vidi »
Offline coromonadalix
Re: Fluke 45, optocoupler replacement
« Reply #1 on: August 29, 2018, 11:59:31 pm »
If i search IL11  optocoupler,   as i see it on an teardown photos : https://www.flickr.com/photos/eevblog/with/21129692555/
Google gives :  Siemens  IL9 IL10 IL11 series
http://pdf.icpdf.com/PdfOld/icpdf_datasheet_1/IL9_datasheet_19792/325327/IL9_datasheet.pdf
Seems to be a perfect fit ...
« Last Edit: August 30, 2018, 12:07:30 am by coromonadalix »
The following users thanked this post: vidi
