Reviving an old topic.
I solved this problem at the time by buying parts from Tektronix:
Item 6Item 5And this fixed that scope.
3D Printing solutionI have another scope that requires the same parts. I recently bought a 3D printer and I have been learning how to use Fusion 360. I thought it would be a nice project to build replacement parts.
Original ComponentsThe hub is the most complicated part:
Here are the printed parts:
I will also have to make this metal part:
Installed on the scopeIt took a couple of goes at each part to dial in the dimensions.
I am quite impressed with the results from the 3D printer.
Regards,
Jay_Diddy_B
