Author Topic: Simple PCB lifted pad question  (Read 3388 times)
Offline hakuTopic starter
« on: May 09, 2017, 12:24:28 am »
Hi everyone
Very new to all this and not so electronic savvy so please forgive if this is a silly/obvious question.
Was trying to replace a relay and some caps without proper desoldering tools (very silly) and managed to lift off some pads.  The PCB came out of a mini fridge that I was wanting to repair (the starter relay and compressor are okay :D).  I ended up buying a proper desoldering gun and got everything apart without more damage.
Anyway,
There are 2 PCBs stacked on top of each other, held together by soldered legs/pins, circled in red here:
The pad that lifted was one of the set of legs/pins, as pictured here:
My question is, was the lifted pad attached to anything pertinent?  From my inexperienced eyes, I don't see it being connected to anything obvious? unless the dark green areas mean something...
-if it was connected to something pertinent, how should I proceed in fixing the pad?
Online ataradov
    • Personal site
Re: Simple PCB lifted pad question
« Reply #1 on: May 09, 2017, 12:39:02 am »
Dark green areas are actual conductors. It is not a lifted pad, it is a part of the track ripped off. Easy fix - just scrape a bit of solder mask and solder the pin to the open area.
Alex
The following users thanked this post: haku
Offline james_s
« Reply #2 on: May 09, 2017, 12:42:00 am »
You don't even need to scrape off the mask, there are already some exposed areas there, as well as a nearby pad on the same trace.
« Reply #3 on: May 09, 2017, 12:48:08 am »
Hello
Do you mean just solder the 2 pins/legs where the ripped off track here to any of the existing pads where the dark green areas are?  Such as the lines in purple that I drew or where the hole where the "R9" is?
« Last Edit: May 09, 2017, 12:50:33 am by haku »
Online ataradov
    • Personal site
« Reply #4 on: May 09, 2017, 01:21:33 am »
Yes, use those openings in the solder mask as contact points.
Alex
