Good morning, gents!
My little hellion of a nephew (with love, I assure you) decided that my DP823 would be a great thing to pull to the ground. Lo and behold, broken LCD. I tested most of the other functions through the programming interface, and all else seems normal.
I managed to disassemble the supply and remove the broken LCD, which appears to be a TM035KDH03 QVGA display. Before I order one to replace, is there anything particular about the display that I should know about? Alternately, are there any equivalent displays that would work?
Thanks!
Side note: If anyone has one of these displays sitting around, I'd be happy to work out a deal for it
