Author Topic: Siglent SSA3021X input protection diode  (Read 2118 times)
Offline Zbych_Topic starter
« on: September 19, 2021, 08:26:37 am »
Can someone tell me what diode is used to protect input of SSA3021X spectrum analyzer? I guess due to frequency range it is something with low capacitance.
Offline thinkfat
    • Matthias' Hackerstübchen
Re: Siglent SSA3021X input protection diode
« Reply #1 on: September 19, 2021, 09:03:47 am »
NXP PZU22B maybe.
« Reply #2 on: September 19, 2021, 11:09:22 am »
Hi thinkfat,
I think zener diode has to much capacitance to be directly connected to RF input.
Maybe U5 is zener diode, but I would bet GS is switching one (forward voltage is ~0.8V)
Package seems to be SOD-723, it is about 1mm long.
« Last Edit: September 19, 2021, 11:18:11 am by Zbych_ »
Offline thinkfat
« Reply #3 on: September 19, 2021, 06:54:19 pm »
I went by the top mark "GS" and the package. It could be SOD-323F just as well.
Edit: well, no. SOD-323 is a bit bigger than what you have there...
« Last Edit: September 19, 2021, 07:14:10 pm by thinkfat »
Offline Ordinaryman1971
« Reply #4 on: September 21, 2021, 04:21:32 am »
My SSA3021X is about 7.4db low..., would it be a problem with one of those diodes being blown... I never really thought to fix it, just got used to error.... but I would be interested in fixing it if it's as easy as to replace the protection diode...
Offline thinkfat
« Reply #5 on: September 21, 2021, 06:03:06 am »
This might fit:
https://www.mouser.de/datasheet/2/80/CDSP400_G_RevB966584-2505193.pdf
Capacitance is about 3pF when reverse biased with 500mV.
It's not the original type, but you might get away with that.
EDIT: https://www.mouser.de/datasheet/2/408/BAS516_datasheet_en_20161020-1139675.pdf might be even better, 0.35pF in SOD-523 package.
« Last Edit: September 21, 2021, 06:10:17 am by thinkfat »
Offline fzabkar
« Reply #6 on: September 21, 2021, 06:39:59 am »
If it's a protection diode, then the unit should run without it. That should enable you to determine whether it is the problem.
Offline thinkfat
« Reply #7 on: September 21, 2021, 09:33:12 am »
The datasheet capacity might actually not be that relevant, since diodes have smaller capacity when reverse biased. But in any case, I think you can just use any fast silicon switching diode, just search by footprint and select for smallest recovery time ( < 2ns seems to be good).
« Reply #8 on: September 22, 2021, 07:40:06 pm »
I received response from Siglent with diode part number. It is obsolete PIN diode, SCD-80 package.
Unfortunately they asked me to not share the number on forum.
« Last Edit: September 22, 2021, 07:45:48 pm by Zbych_ »
Offline fzabkar
« Reply #9 on: September 23, 2021, 12:54:04 am »
You can still tell us which diodes are suitable substitutes. ;-|
« Reply #10 on: September 23, 2021, 04:06:22 am »
Online gamalot
  • Correct my English
    • Youtube
The following users thanked this post: tautech, fzabkar
« Reply #12 on: September 23, 2021, 07:42:29 pm »
I guess they are Infineon BAR63-02V
https://www.infineon.com/dgdl/Infineon-BAR63SERIES_DS-DS-v01_01-EN.pdf?fileId=5546d4625e763904015ec363284f64d0
Perfect !  :clap:
S is the date code.  :palm:
Many thanks for coming to the call for help.  :-+
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #13 on: June 10, 2022, 09:28:20 pm »
F me !! now my SSA3021X is DEAD.. no RF input,
I know exactly what happened, an RF unit I was testing with BNC adapter lost its gnd, and the unit was not correctly earthed !!
i normally alway have a DC block or attenuator on my analyze, but today i forgot it..
waranty is not going to fix it ...
anyone tried to fix this ?
is it just this diode ?
can i measure it ? from the outside ?
before i open ?
any other parts might be broken ?
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
« Reply #14 on: June 10, 2022, 09:45:13 pm »
Further recent discussion starts here:
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg4228897/#msg4228897
Leads to another thread that leads to a video with a RF input ~15dB down repair....all worth a study.
« Reply #15 on: July 17, 2022, 11:29:34 am »
BTW, I've found a video showing front-end repair. Input diodes types are in the video description.
It's a pity that Dr Min Zhang didn't put SSA model name in the title, it would be much easier to find.
The following users thanked this post: fzabkar
Offline fzabkar
« Reply #16 on: July 18, 2022, 07:06:21 pm »
Fixing and protecting the RF Input of a Spectrum Analyzer (Siglent SSA 3021X):
http://emccompliance.co.uk/fixing-and-protecting-the-rf-input-of-a-spectrum-analyzer
Chips need to be replaced:
PIN Diode D31, D33 ------- BAR63-02V(Infineon)
Voltage regulator diode D32, D34 ------- BZX84J-C30(NXP)
GaAs SPDT Switch U1 --------- MASWSS0181TR (M/A-COM)
If it is a Rigol DSA815 unit, chipset is HMC221B
