Hi All, posting my quick fix incase it is useful for anyone else.
I have several Siglent SPD3303X-E power supplies, they are excellent value for money! but...
2 of them reboot after running for a short time (about 10 mins) and continue to reboot occasionally during use. Obviously this isn't good enough for lab equipment so i disassembled them to see what I could find. The problem is pretty typical of a thermal issue so I had a look around with the FLIR thermal cam and found a few hot spots around the devices. There are a couple of current sensing shunt resistors that get up to about 85 degrees but they max out there and don't really get any hotter.
The main problem appears to be the small bridge rectifier in the front panel power supply, it gets to about 105C+ and then the device reboots, it cools slightly and runs for a bit longer before doing it again.
There are a few things that could be done to fix this problem (not an exhaustive list obviously):
- The bridge rectifier could be replaced with a higher current option
- It could be soldered higher above the PCB for better cooling
- A small heatsink can be used to cool it down a bit
I chose to do a test with a small copper heatsink just stuck on top of the rectifier with thermal adhesive and the temperature difference was dramatic! After running each test overnight to give it enough time to reach steady state:
- Before: 105C and rebooting
- After: 67C and not rebooting anymore
Not sure how they could possibly send these out with several components running so hot, they obviously didn't do much thermal testing! Out of the 4 units I have, 2 had the rebooting problem and the other 2 didn't but all of the bridge rectifiers ran extremely hot. Atleast it's an easy fix, I hope this info can help someone else.
