Hello everyone.
I own a Siglent SDS1104x-e which has been working ok for 3 years, bought it new.
Today, suddenly, it stopped working. It's stuck at the booting routine, here's what it does:
- Fan turns on
- Power button turns on
- Internal relay turning on and off
- screen shows nothing
- Rest of the buttons lights on
Already solved, here's the solution:
The firmware was never updated. So this is most probably an old firmware bug.
I had to start the scope with both channel 1 and channel 2 probes connected to the cal pin. This way for some reason started.
After that , updated to the newest firmware available and problem solved.
If any of you guys is thinking on buying a siglent scope, update the firmware as soon as new ver. are available
