Author Topic: Siglent oscilloscope screen SHS1102 frozen  (Read 1049 times)
Offline Alex2troisTopic starter
« on: September 25, 2024, 08:08:47 am »
Hello everyone ;)
I have a broken Siglent SHS1102 oscilloscope, the screen remains blocked at startup, even when pressing the scop button, no reaction
Just once pressing the F1 key:
ver_soft 3.01.02.02r7
ver_hard: 8-21-3.3
Of course impossible to boot from a USB key
Do you have a solution to offer me?
I am not an electronics engineer but only an electrician
Is it possible to download the SHS1000 firmware and then load it with a programmer?
Can the RT809HSE programmer be used?
Thank you, see you soon
Online coromonadalix
Re: Siglent oscilloscope screen SHS1102 frozen
« Reply #1 on: September 25, 2024, 11:16:24 am »
ask Tautech member here,  maybe there is some recovery procedures / package ...
« Reply #2 on: September 25, 2024, 07:19:08 pm »
Merci à toi Coromonadalix, je vais essayer :-+
« Reply #3 on: September 25, 2024, 07:35:06 pm »
Avec Plaisir    with pleasure
Donne nous en des nouvelles,  give us some news ...   :-+
Offline tautech
« Reply #4 on: September 26, 2024, 06:46:05 am »
Hello everyone ;)
I have a broken Siglent SHS1102 oscilloscope, the screen remains blocked at startup, even when pressing the Scope button, no reaction
The only recovery method available in pressing SCOPE rapidly at Boot.
Try as many times as is necessary.
Download attached video.
Remove .txt extension required to upload .mp4 files to the forum.
« Reply #5 on: September 27, 2024, 05:37:04 pm »
Bonjour à tous,
J'ai essayé une vingtaine de fois rien à faire  :-//
Je ne sais plus quoi faire...
La batterie est neuve et la pile 2032 également
Merci pour votre aide
Alexandre
Hello everyone,
I tried twenty times to no avail :-//
I don't know what to do anymore...
The battery is new and the 2032 battery too
Thank you for your help
Alexander
Offline tautech
« Reply #6 on: September 27, 2024, 08:04:05 pm »
Replacement mainboards are no longer available.  :(
I have been working with HQ to find a solution.
« Reply #7 on: September 27, 2024, 09:13:55 pm »
Bonjour Tautech,
Il y a du nouveau, j'arrive à naviguer dans le menu user mais les clés usb ne sont pas reconnues
J'ai essayé en fat, exfat, ntfs rien à faire ...
Faut il une clé particulière ou peu importe ?
Sur cette clé j'ai installé SHS1000.cfg
SHS1000_V5.09.01.05.ADS
Merci
Hello Tautech,
There is something new, I can navigate the user menu but the USB keys are not recognized
I tried fat, exfat, ntfs nothing to do...
Do you need a special key or whatever?
On this key I installed SHS1000.cfg
THANKS
Offline tautech
« Reply #8 on: September 27, 2024, 09:21:57 pm »
Hello Tautech,
THANKS
FAT32 with 4k clusters is the USB requirement.
Offline tautech
« Reply #9 on: September 27, 2024, 09:34:01 pm »
There should be NO need for CFG files.
Firmware version 5.09.01.07 is the latest/last firmware version:
https://int.siglent.com/upload_file/zip/firmware/Hand-held_oscilloscope/SHS1000_5.09.01.07_EN.zip
« Reply #10 on: September 28, 2024, 05:34:59 pm »
Bonjour Tautech,
Voici les nouvelles :
Il met environ 16 secondes à démarrer
Pour quelle raison l'écran était figé, je n'a pas de réponse à vous donner
Concernant la mise à jour :
J'ai testé avec de nombreuses clés usb (fat32 4K), l'appareil ne détecte rien
J'ai bien 5VCC sur la clé
Peut être une mauvaise soudure sur data+ ou data- ?
Merci, à bientot
Alexandre
Hello Tautech,
Here is the news:
It takes about 16 seconds to start
Why the screen was frozen, I have no answer to give you
Regarding the update:
I tested with many usb keys (fat32 4K), the device does not detect anything
I have 5VDC on the key
Maybe a bad solder on data+ or data-?
Alexander
Offline tautech
« Reply #11 on: September 28, 2024, 07:51:47 pm »
Hello Tautech,
Here is the news:
Alexander
Which version of firmware does Utility/System Status report ?
Are you operating from the battery or from the mains charger ?
« Reply #12 on: September 28, 2024, 08:56:15 pm »
 Tautech,
ver_hard : 8-21-3.3
J'ai essayé de faire la mise à jour sur secteur 230/12V avec batterie et avec batterie seulement : sans succè :(
I tried to update on 230/12V sector with battery and with battery only: without success :(
Encore merci pour votre implication ;)
Offline tautech
« Reply #13 on: September 28, 2024, 11:52:08 pm »
Does SHS1102 power On/Off correctly ?
ver_soft 3.01.02.02r7 is first firmware and if possible it should be updated.
There may be a USB fault preventing you from updating however I would first suspect a incompatible USB stick.
Reformat others you have to FAT32 with 4k clusters and try them.
Place the ADS file from the firmware ZIP package into the root folder of the USB stick which makes it easy to find and navigate to.
« Reply #14 on: September 29, 2024, 08:00:06 pm »
Bonjour Tautech,
J'ai une bonne nouvelle
J'ai eu de la chance  :phew: : sans doute dessoudé involontairement en examinant toutes les soudures ou alors une mauvaise soudure sur le contrôleur usb...
J'ai téléchargé le datashet du ISP62BD, je pense que la patte 63 (D0) et 64 (D1) était en contact (court circuit) ou seulement la patte 63 (D1) sans contact, avec un peu de soudure et c'est parfait !
Maintenant dès que je mets une clé usb l'appareil me l'indique instantanément : "clé USB branchée" "clé USB débranchée" ;)
La mise à jour du firmware shs1000 5.09.01.07 s'est bien déroulée
Le temps de démarrage du shs 1102 est d'environ 16 secondes
Donc maintenant je suis en version software 5.09.01.07 et hardware version 8-21-3.6
Une autre question :
Que veut dire cfg ? Configuration peut être...
Un grand merci à Tautech et coromonadalix pour m'avoir consacré un peu de leurs temps  :clap:
I have good news
I was lucky   :phew: : probably unsoldered unintentionally while examining all the solders or a bad solder on the usb controller...
I downloaded the ISP62BD datasheet, I think that pin 63 (D0) and 64 (D1) were in contact (short circuit) or only pin 63 (D1) without contact, with a little soldering and it's Perfect !
Now as soon as I insert a USB key the device instantly tells me: “USB key plugged in” “USB key unplugged” ;)
Firmware update shs1000 5.09.01.07 went well
Boot time of shs 1102 is approximately 16 seconds
So now I am in software version 5.09.01.07 and hardware version 8-21-3.6
Another question:
What does cfg mean? Configuration can be...
A big thank you to Tautech and coromonadalix for devoting some of their time to me  :clap:
« Reply #15 on: September 29, 2024, 08:20:19 pm »
Tautech,
Est ce qu'il y a des pilotes pour W10 ?
Pour faire fonctionner EasyscopeX
Merci
Are there drivers for W10?
To operate EasyscopeX
THANKS
« Reply #16 on: September 29, 2024, 08:30:54 pm »
Tautech,
C'est encore moi désolé, je n'est pas compris le réglage des compensations probes
It's me again sorry, I don't understand the probe compensation setting  :o
Thanks
Offline tautech
« Reply #17 on: September 29, 2024, 09:04:16 pm »
I have good news
Good work Alex !  :clap:
Enjoy.
CFG files are for configuring the displayed brand, say for a rebrand that Siglent supply.
NIVISA must be also installed as it contains the USB connectivity drivers.
The NIVISA Runtime package is the minimum requirement to get these drivers.
The EasyScopeX install instructions give guidance and NIVISA should be installed first otherwise W10 will assign the incorrect driver for your scope or other device.
If you have problems connecting to EasyScopeX I have a troubleshooting document if you need it.
See P4
https://siglentna.com/wp-content/uploads/dlm_uploads/2017/10/SHS1000_UserManual_UM03010-E07C.pdf
« Reply #18 on: September 30, 2024, 07:29:35 am »
Bonjour Tautech,
Comme j'aimerais vous avoir comme voisin ;)
Je ne trouve pas ce téléchargement chez Siglent
Connais tu un site fiable sans risque ?
Merci, bonne journée
Alexandre
How I would love to have you as a neighbor ;)
I can't find this download from Siglent
Do you know of a reliable, risk-free site?
Thank you, have a nice day
Alexander
Offline tautech
« Reply #19 on: September 30, 2024, 07:33:33 am »
The download link above is to Siglent HQ in Shenzhen and is 100% trustworthy.
« Reply #20 on: September 30, 2024, 07:53:51 am »
Le lien ne fonctionne pas chez moi  :-//
The link does not work for me
Thanks
« Reply #21 on: September 30, 2024, 08:01:42 am »
Est ce que c'est ce lien avec demande enregistrement ? :
Is this link with registration request? :
https://www.ni.com/fr/support/downloads/drivers/download.ni-visa.html#544206
Thanks
Offline tautech
« Reply #22 on: September 30, 2024, 08:19:50 am »
Oh, you did not say Runtime download.
https://download.freedownloadmanager.org/Windows-PC/NI-VISA-Runtime/FREE-5.4.html
It's 73MB but much better than 500+ MB for the full NIVISA install.
Will download as: visa540_runtime.exe
