Thanks. I'll give that a try. If it doesn't work I I'll have to wait for a parts scope or sell it for parts... Or just use it for experimentation.
Quote from: jonathanlemoine on March 17, 2020, 12:46:03 amThanks. I'll give that a try. If it doesn't work I I'll have to wait for a parts scope or sell it for parts... Or just use it for experimentation.Hold your horses....from factory tech support:From the fault, we adjuge that it is most possible the hardware fault. Need to replace the mainboard. This customer come from Canada. So please ask him to contact SIGLENT American office or info@siglent.com
Is it behaving always the same during startup ?You could try ice-spray on memory, flash or Xilinx chip.Also measure supply rails with scope if there is some dips.Maby re-soldering/re-flowing (or replacing) ram/flash could also help if they are not BGA.
Ubifs doesn't have a recovery tool, but you can try reading each file to force the kernel to check them. Then try remounting the file system read-write.
Quote from: tautech on March 17, 2020, 10:07:32 amQuote from: jonathanlemoine on March 17, 2020, 12:46:03 amThanks. I'll give that a try. If it doesn't work I I'll have to wait for a parts scope or sell it for parts... Or just use it for experimentation.Hold your horses....from factory tech support:From the fault, we adjuge that it is most possible the hardware fault. Need to replace the mainboard. This customer come from Canada. So please ask him to contact SIGLENT American office or info@siglent.comThank you. I will contact them. I figured as much. But I'm thinking it will be expensive as thinkfat says. I'm not in need of a board right away because I have a SDS2102 (hacked of course). If it's resonable (let's say $200) then sure, it's a no brainer.
Serial: SDS1ECDX3R****
I contacted Siglent with my problem.
They responded and said that they would do a warranty if the serial number is withing the 3 year period. So I just sent then my serial and am currently waiting for a response.
Thanks! Yeah I figured it would be too late today. I have nothing but time for a little while anyway. I have lots of other projects that I would like to start. I don't think I'll check any anything else until I hear back. Just incase I do something very bad. Lol it would be my luck. It's a little disappointing though. It's so much more gratifying fixing something yourself.
Oh it will be good to get it fixed under warranty for sure. Actually I only bought it with the hope of flipping it. I wanted to play with it but I wasn't sure I wanted to keep it. I have a 2102 not the 1202x...I bought it off eBay as an open box item and it said it was a 2102x. I was disappointed when I opened the box and found it was not an x model.. But it was new. Seller was a dick and didn't take responsibility for it but for the price it was still good so I kept it. I also have a 500mhz HP but it's not as cool as the new ones. I don't do this for a living. I'm a heavy equipment operator, electronics is just a hobby. Learn a little bit with everything I fix.
Just wished these chinese manufacturers would get a grip on their model numbering scheme.SDS1000DL+, SDS1000CML+, SDS1000CFLSDS1000X-E, SDS1000X, SDS1000X+SDS2000X-E, SDS2000X, SDS2000X Plus,SDS5000XGimme a break
