Author Topic: Siglent 1202X-E recovery  (Read 6477 times)
Offline jonathanlemoineTopic starter
« on: March 16, 2020, 12:30:37 am »
Hi there guys. I picked up a Sds1202x-e as a repair project off of EBay. The listing said it had a booting problem. I did manage to get it to boot eventually by a hard reset and a long 30min wait. When it did boot it displays something like noise on the screen. Full length of the graticule no matter what scale. It has the latest firmware and nobody has been inside of it. I was thinking maybe a firmware flash gone wrong? I've been trying to flash othe firmwares with no luck. Mostly because getting it to reboot is nearly impossible. You can spend hours trying to get it to boot into the main screen again. It looks new. Came in the original box with all accessories and manual. Nobody has even changed the little probe rings.
Offline tautech
Re: Siglent 1202X-E recovery
« Reply #1 on: March 16, 2020, 01:16:52 am »
Hmm, interesting.  :-//
Have you tried to do the Self Cal ?
Wonder why the previous owner didn't try for a warranty claim ?
« Reply #2 on: March 16, 2020, 02:07:41 am »
I have done a self cal and it took a little of it out but not much. It takes anywhere from 1hr to never to complete. Usually it just hangs. I have managed to downgrade the firmware and if anything it made it worse. I'm leaning towards a hardware issue now. I may have to crack it open. I agree it's very strange that someone didn't try for a warranty claim. it only had 22 boots when I got it. I am now up to 144 and I have only been playing with it for a day.
Offline tautech
« Reply #3 on: March 16, 2020, 02:58:17 am »
OK thanks. I'll go fishing for some answers/solutions for you.
« Reply #4 on: March 16, 2020, 10:11:18 am »
 :palm: well this doesn't look normal. Upon further inspection it looks like the glue they used to fix the heatsink to the processor. Someone got messy at the factory. It's a thick, very hard substance. Crappy. :palm:
« Reply #5 on: March 16, 2020, 10:20:44 am »
All around the heatsink. Not sure if it's the problem though. It makes sense that it would be the reason that it hangs and won't boot half of the time.
« Reply #6 on: March 16, 2020, 10:46:28 am »
Not conducive though. |O Moving on. Going to have a look at voltages and ripple on the outputs of the PSU.   :-//
« Reply #7 on: March 16, 2020, 11:54:11 am »
All voltages on the main board appear to be correct and all clock signals are present.  :o That's about all I can do. Well maybe I'll hook up a serial connection and see what that is saying....gurrrrr |O
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #8 on: March 16, 2020, 12:54:54 pm »
That could be a good idea. Of course provided Siglent chose to output some kind of helpful diagnostic messages. There's a Linux system working under the hood. If you get a console, please post the boot log, I'd like to have a look.
« Reply #9 on: March 16, 2020, 01:01:29 pm »
Here is a text file with the output..this is where it fails to boot. FPGA problem? I'll try to get one where the boot is sucessful also. I wasn't sure if I should attach it as a file or just paste it in here.it
edit:
Actually finally finished booting with no further output. So this is it.
« Last Edit: March 16, 2020, 01:04:23 pm by jonathanlemoine »
Offline thinkfat
« Reply #10 on: March 16, 2020, 01:04:34 pm »
I'd attach it as a file. Easier to handle than inline text.
Offline Mark19960
« Reply #11 on: March 16, 2020, 01:13:05 pm »
It's not happy about one of the FPGAs in the instrument and that doesn't bode well.
insmod: can't read '/usr/bin/siglent/drivers/udc-xilinx.ko': No such file or diy
Can't load the driver to even talk to the FPGA?
There are other things in there like a CRC error and it not being able to copy from USB.
Offline thinkfat
« Reply #12 on: March 16, 2020, 01:15:58 pm »
edit:
The log lines seem to have been cut at 80 columns. But there's nothing jumping out, actually. Can you configure your terminal program to capture the full lines and add a timestamp in front of each line?
The following users thanked this post: jonathanlemoine
Offline goaty
« Reply #13 on: March 16, 2020, 01:24:26 pm »
So the TOis a similar unlucky person like me who also tries to buy broken stuff for repair but doesn´t have Shariar´s luck (signalpath) for finding graeat equipment with minor errors  ;D
Offline thinkfat
« Reply #14 on: March 16, 2020, 01:28:00 pm »
The CRC error is normal if the u-boot environment has no backing store in the NAND (because it isn't provided or it has never been initialized).
Not being able to load the linux kernel from USB is also not an error. That looks like part of the development setup still part of the firmware. It successfully loads the kernel from NAND afterwards.
The FPGA related messages are a bit suspicious, but they could be just normal debug output. Maybe if you look around on the forum a bit you'll find a boot log from a working device. I know Dave Jones has put boot logs from Siglent scopes up for download, maybe check out the thread regarding the test and teardown of this scope.
« Reply #15 on: March 16, 2020, 01:40:52 pm »
i copied and pasted from the terminal. On my screen the colums weren't  cut off. maybe something happened when i copy it to LibreOffice. Mayabe I should make the file with the command line instead?
Maybe next time. I don't do this often guys sorry. Here is an odt file instead of text incase something was lost in the txt format.This time where it goes into a kernal panic. As you can see it fails 785s into the boot process. It does take a long time to boot when it does.
Offline Mark19960
« Reply #16 on: March 16, 2020, 02:37:20 pm »
ODT looks better to me.
There is a kernel panic related to the FPGA.
Might be worth some checking about to make sure all of the power supplies for the FPGAs are up and running.
Offline thinkfat
« Reply #17 on: March 16, 2020, 02:45:01 pm »
The kernel panic certainly isn't a good sign. It looks like the software is waiting for a certain status from the FPGA which doesn't arrive.
[  785.178931] [000010c4] *pgd=00000000
This means the CPU tried to access memory that isn't mapped, could be the equivalent of a null-pointer de-reference.
The stacktrace is also a bit weird, it failed in sched_show_task(), called from rcu_print_detail_task_stall_rnp(), this is a standard diagnostic kernel function that belongs to the RCU subsystem (read-copy-update). It appears the kernel detected a stuck task and tried to call it out and then panic'd while it tried to print the task data.
It sounds like there's something very wrong, at least something that the software was never prepared to handle sensibly.
« Reply #18 on: March 16, 2020, 03:01:36 pm »
This is interesting. Figured I'd try to see why it won't complete a recalibration.
Offline Mark19960
« Reply #19 on: March 16, 2020, 03:14:00 pm »
I know there are chaps a lot better at this than I certainly but some module that may not have loaded and then a bunch of errors about a read-only filesystem.
Seems to start pointing in my mind to the flash being corrupted or bad.
« Reply #20 on: March 16, 2020, 04:01:57 pm »
Maybe someone will have an idea. Until then I have a paperweight. I thought about reflowing the FPGA but I don't know if that would do anything and may just make things worse.
Offline tautech
« Reply #21 on: March 16, 2020, 06:40:15 pm »
 :-// Didn't think you'd be so keen to rip it apart and go sniffing just yet.
I haven't heard back from Siglent but now they have lots of additional info to digest.  :)
« Reply #22 on: March 16, 2020, 08:11:47 pm »
I should be leaving it alone but I figure I might as well learn some things on something that doesn't matter if I break it... Don't get me wrong I'd love to get it working. I bought it for $285 CAD + shipping so it would be an expensive paperweight. Right now I'm just sniffing around to see if I can see anything odd... The trouble is I don't know enough. For instance why is the root filesystem mounted read-only. How can anything be configured if nothing can be changed? Seems odd. But I know nothing. I appreciate everyone's help though. I really need it. I'm aware it may be beyond my ability to fix in the end but I like to try. It's all a learning experience. :popcorn:
Offline thinkfat
« Reply #23 on: March 16, 2020, 08:29:29 pm »
I see you're using minicom. Ctrl-a w switches on line-wrap mode, ctrl-a l allows logging into a text file. Ctrl-a n toggles different timstamp modes.
I didn't see rootfs mounted read-only in your first log, but if it is, that's a sign of a corrupted NAND flash.
That's probably the last thing I'd try. Carefully applied pressure might have the same effect temporarily and be less dangerous.
« Reply #24 on: March 16, 2020, 09:47:53 pm »
Ok so I tried applying some pressure too the chips while booting and it had no effect.
Any file I open with vi is read-only. Also I can't create any files as it returns an error that the filesystem is read-only.
I guess we found the problem then? Corrupted NAND? I take it there is no fix like a re-flash? Ah well. It was a nice journey.  :horse:
