I was looking for a replacement side key for an old smart phone MobiWire STARXTREM 5. Unfortunately there is very little to be found online.
I bought one replacement side key which is for a Huawei phone, which has the right connector and plugs in alright. I was hoping it might have the right key assignment/proper assignment of the connector pins to the buttons, but apparently it doesn't, as it makes the phone think several keys are pressed or still held down, when that's not the case.
For reference that's the replacement I tried (NOT the original from "my" phone, which is broken):
https://www.amazon.de/dp/B081YVHWHLThe model number given on the flat flex cable of the original (now broken keys) was: WQ30 H556 SIDEKEY
Does somebody know a compatible sidekey by any chance? Or it not, a way to modify such a flat flex cable to correct the button assignment, or at least attach normal magnet/hookup wire? The connectors are tiny, but maybe someone has a trick up their sleeves.
