Author Topic: Need help !(Hameg 504 scope sweep line not in the middle)  (Read 898 times)
Offline cnqhdszqTopic starter
  • Country: cn
« on: April 11, 2020, 12:31:42 pm »
I bought a 2 hand Hameg 504 scope .
At the begining ,the powersupply unit does not work.After 3 day's work .it works fine  now  . but when I pressed "AUTOSET " the trace line is not in the middle ,it is deviation to left  of centre. I must  move it by the "X-POS" knob ,When I press "AUTOSET "again ,the trace move to the left again.
When I open the "MANUAL ADJUSTMENT MENU" and select the "SWEEP GENERATIOR" it says"PRESS SECURITY KEY !"
What should I do next ???? .
« Last Edit: April 11, 2020, 12:36:28 pm by cnqhdszq »
Offline aqibi2000
Re: Need help !(Hameg 504 scope sweep line not in the middle)
« Reply #1 on: April 11, 2020, 01:56:51 pm »
That is a nice scope!
Tinkerer’
  • Country: cn
« Reply #3 on: April 12, 2020, 02:58:41 am »
thanks !!
