I was (spoiler - still am) trying to 'fix' a Sennheiser EW300 G2 - SK300 G2 body pack transmitter 830-866 MHz
This device had leaked battery corrosion - fortunately - only on the battery contacts (so I thought).
I did a total teardown and cleaned all on the modules after a visual inspection (my first mistake).
Everything appeared to be cleaned - no visual signs of corrosion on main PCB.
So I reassembled the unit - checked everything once again - and then powered - up the unit
NOTHING!!
No power-up - unit appears to be dead.
Well I thought this was too easy - surely it cannot be as simple as cleaning any remains of corrosion and making sure no tracks are shorted / broken.
So back to debugging.
Power seems to be going to PCB
I partially disassembled the unit once again - this time checking the the power is going to the PCB directly - yep! all good here - visual inspection was OK - so I decided to power-up the device by directly 'depressing' the on/off logic microswitch.
I pressed - and within seconds could 'smell' something - KILLED BATTERIES immediately - and then had a closer look at where is the 'damage' occurred
Interesting thing was that when pressing the on/off button on the assembled unit BEFOR - nothing happened - no 'small' nothing - so I obviously assumed (second mistake) that nothing critical happened - perhaps there was no power going to the main circuitry - because on/off logic microswitch did not engage (button not pressing due to poor alignment?)
BINGO
- yes - the button was not engaging - but when I pressed the button manually it did engage - and 'puff' there was a short somewhere.
MY FIRST MISTAKE was not examining the circuitry under a microscope
My microscope was not available (on loan to someone) - so I had a real good look at the complete PCB logic circuitry with my 'pissweak' magnifying glass.
Needless to say - my poor vision and the bad magnifier - resulted in missing some corrosion between the tracks neat the LT chip and nearby components.
Green corrosion + green PCB + poor visual inspection = BLOWN components!
Looks like the 'short' caused by the corrosion was sufficient enough to smoke the LT chip and possibly some other components.
I took a pic with my mobile phone camera (better than my eyes - should have used this in the beginning and this post would not exist
) and could see that there is a 'burn' mark crater on the LT chip - most likely fried.
Dave did a teardown on one of these devices some time ago - there are many variants - but they appear to be using the same power / charging circuitry.
I need to 'fix' this unit - and was hoping that someone WHO HAS HAD EXPERIANCE WITH SIMILAR PROBLEM (blown ltc3401? and I guess possible 'other devices as a result'??)
https://www.analog.com/media/en/technical-documentation/data-sheets/3401fb.pdfcould point me in the right direction with regard to best approach to instigate the fixup procedure - needless to say I will need the LT chip - so any tips of supply here in UK (trying to save time) would be most welcomed.
Like - do a 'blanket replace' of all 'dodgy looking' components??
What worries me most is not to have 'blown' other parts of the board - but I guess not - as the 'main' power would be first to blow (expensive fuse
) and save the other critical parts of the board.
As I write this post - I managed to find a service manual - so will share this with everyone here - see below.
I have LEARNED A VERY IMPORTANT LESSON
DONT EVER power-up after corrosion cleanup UNLESS you EXAMIN the PCB / mainboard WITH A MICROSCOPE
It is possible to still have minute traces of corrosion - enough to 'short' circuit critical components - and YOU WILL NOT SEE THEM unless you use a MICROSCOPE!
The other really stupid mistake was not to supply extremal power (via jumpers) and simply put the batteries inside the unit.
If I had planned for the worse - some possible remains of corrosion which I missed (I did miss it) - then providing external power with a current limit set at miniscule level - would at least give me some protection at the massive current draw due to the 'short' and shut down the power before any damage!
Well I did learn something here - at a BIG expense to me - blown components!
I hope this 'story' will be useful to everyone attempting to 'fix' PCB's with corrosion - please avoid the stupid mistakes I made
