10/4/18 UPdate: I will be replacing all analog ICs and semiconductors on the front and back of the old and new versions of the MF and I have completed the list for part ordering.
Total cost for replacing all parts on the top side listed for 1 FG was about $110.00 including shipping.
Ok, so I OV'd my CH1 of SDG1025 FG.
It's 280 dollars to have it repaired at siglent (including shipping), or 319 for a new one.
I tracked it down to a bad THS3095 (U19) which was about a 10 dollar part, and a bad 25 ohm resistor (R154) from a secondary opamp CLC1606 (U46). [Side note: the new SDG1025 now use a LMH6702 as U46 and U58 while the rest of the CLC1606 (not available) have been replace as OPA695 (U37,U40,U52,U51,U48, and U38) ]
I replaced it, and Ch1 worked perfectly, until I made sure Ch2 worked too as well.
Ch2 was outputing lower voltages so I did a self calibration.
Then both Ch1 and Ch2 didn't want to work at all.
I opened it back up and found a solder ball had somehow got flung between two pins of the opamp 5166iSZ (U59).
It was between the 5V and the output of the op amp.
I replace U59, and both channels were still not working.
After some testing, I found the relays don't work.
There are 2x 5V power points on the FG, and they are not connected together.
The relays (and other components) operate on one 5V (VCC5V) while all of the analog op amps from Ch1 and Ch2 operate on the other (+5V).
The 2 ICs that control the relays are UN2003A (U74 and U71, which are 8 transistor/buffer inverters per package), and those are controlled by 2x 74ahct595 which have the markings on the IC of HB595 (U36 and U39, which are serial to 8 parallel registers with the first register feeding the second with the last inverted parrallel output.) All of these ICs run off of the VCC5V output.
Testing the input to the series data input of the first register has found that the signal is high and does not change with a repeatable sequence when the Ch1 or Ch2 output buttons are pushed. (although I can still hear one of the relays switching)
The series data input of the first register leads to the fat ribbon wire to the interface panel, and is leading to both Ch push buttons.
The other side of the capacitive push buttons leads to the ribbon cable interface of the LCD ribbon where, there is a second pin on the interface that is shorted when ch2 button is pushed. This pin leads back down through the fat ribbon cable back the mother board to the 6 pin IC. When the markings on the IC is read from the orientation of the three pins as being the bottom, the package has the marking of:
z16B
It's labeled U60o on the block diagram schematic
The new version is marked:
z166
I've done searches on these parts, and I can't find any information.
If anyone has any ideas or knows what this IC is, or even possible knows what's wrong with this FG, I would be very greatful for your help. I'm in it for the long haul, and I am even looking at replacing the FPGA or the controller if need be but I would like to exhaust all other possiblities first.
Here is what I have so far relating to part numbers an their block diagram number that I'm also including.
---------------------------SDG1025------------------------DAC904E28 pin
U54,U45
Marking on part:
DAC904E
2ACLD9X
NEW VERSION
B3GA4.5ZRelay 8pin
RAL14,RAL15,RAL16,RAL11,RAL18,RAL9,RAL10,RAL19,RAL20,RAL8,RAL12,RAL21,RAL13
Marking on part:
B3GA4.5Z
OLD VERSION
UD2-4.5NU (not available)
Relay 8pin
Marking on part:
NEC JAPAN
UD2-4. 5NU
3A1312F
sn74ahct59516 pin (serial to parallel registers that control the transistors that control the relays)
U36,U39
Marking on part:
(TI insignia)
HB595
34KG4
AXGL
ULN2003A16 pin (transistors that control the relays)
U74,U71
Marking on part:
(TI insignia)
UN2003A
34AG3
P05M
NC7WZ16 6 pin (buffer)
SC-70-6
U60o
Marking on part:
z16B
New
SC-70-6
U60o
Marking on part:
z166
------------------------------Overvoltage and Relay Malfunction IC/Semiconductor Replacement List------------------------------------- OLD version
BAV99 3pin DIODE ARRAY SOT-23
Q3,Q4,QA8,QA9,QA13,QA5,QA10,Q19,Q27
Marking on part:
A7
(sideways)x
NEW version
QA8,QA9,QA13,QA5,QA10,Q19,Q27,[Q3,Q4,Q6,Q7]on backside of MB
Marking on part:
A7
(sideways)x
THS30958pin OPAMP
U19
Marking on part:
3095
TI 18Z
CRZ4G3
NEW version
OPA6958pin
U37,U40,U52,U51,U48,U38
Marking on part:
TI OPA
695
695YV
NEW version
LMH67028pin
U46,U58
Marking on part:
5A5C
LMH67
02MA
(note: OPA 695 looks like it has better performance than the LMH6702, and it was substituted to save money)
OLD VERSION
8pin
U46,U58,U37,U40,U52,U51,U48,U38
Marking on part:
CLC1606
1239
Z1
5166iSZ8 pin
U59
Marking on part:
5166iSZ
B149W7
(Elantec marking)
OLD VERSION
TL072C8 pin
U104,U101
Marking on part:
TL072C
32k
AT88T4
NEW VERSION
TL072C8 pin
U104,U101, [U108, U110]on backside of MB
Marking on part:
TL072C
32k
AT88T4
AQY214S4pin Relay
UA50
Marking on part:
COSMO
Y214S
M27
ISL282108 pin
U103,U91,U106,U102, U89
Marking on part:
28210
FBZ -C
B308FP
NEW version
8512A8 pin
Marking on part:
(sold box with cut out of right pointing equallateral triangle), (# or $$ symbol)
1652
7910
(note: ISL28210 looks like it has better performance than the 8512A, and it was substituted to save money)
OLD VERSION
74HC405116 pin
U47,U42
Marking on part:
(NXP insignia)
74HC4051D
L2K3C806
UnD1314D
NEW VERSION
74HC405116 pin
U47,U42, [U53]on backside of MB
Marking on part:
(NXP insignia)
74HC4051D
L2K3C806
UnD1314D
VCA82214 pin
U26,U25
Marking on part:
(TI insignia)
24CSGEK
VCA822ID G4
ADCMP56220 pin
U35
Marking on part:
2552125.1
ADCMP
562BRQ
adc121s1016 pin
U61_1
Marking on part:
X01C
SBC846BLT3GSOT-23
3pin
QA4,QA3,QA16
Marking on part:
1B 4
(sideways)4
OPA7278 pin
U49
Marking on part:
AUE
32C6
REF3030SOT-23
3pin
U73
Marking on part:
R30F
DAC858016 pin
Q27
Marking on part:
(TI insignia)
D85801
09T
A97R
MMBTH10LT1sot23-3
QA2
Marking on part:
3EM (sideways 4)
PMBFJ309sot23-3
QA1
Marking on part:
49W (sideways 29)
NEW VERSION
LM33914pin
[U27]on backside of MB
------------------------------------ONLY ON BACK SIDE OF NEW VERSION SDG 1025-----------------------------
LM33914pin
U27
TL072C8pin
U108, U110
74HC4051D16pin
U53
Q3,Q4,Q6,Q7
Marking on part:
A7
(sideways)x
Please correct me if you think I got one of these wrong to increase knowledge of SDG1000 series repair.
Thanks
