I asked a friend of mine to send me a schematic about the section of the psu where the problem was.
He draw it by hand and I'm draw colored lines on it, which should represent my thinking where the problem was.
Check the picture.
I assume:
Scene1.:
The whole circuit is not galvanic separated from the main,so when I put my probe to measure the NE555 that was the same as I would measure a BR direct with my scope, putting the alligator clip to the DC gnd and the DC positive of the BR.
That would finish up in a big bang if the alligator clip of my scope is connected to earth.
The green line on my drawing is the path where the current was travel on every half cycle of the L line, also on the N line.
That means from my opinion does I shorted out the D1 and than the D2 or vise verse through the earth, and so I was connected directly to the main.
Al these happend even if I connected the scope to the GND of the NE555.
The pcb is from the upper side filled very hard with some white rubber think, so it is very hard to identify the component labeling etc.
The bottom side is clear.
Scene2.:
Maybe an over voltage was traveled through my scope tip.
But, I don't really think so.
The max voltage of the NE555 should be not more than 18V.
My tip should handel much more voltage around 600V DC.
So, that should not be the case, only if the NE555 was bad and on his output was more voltage then suspected.
But, in that case, I assume the NE555 would be burned, I mean exploded.
Conclusion:
I stand on the theory does I made a mistake and shorted out one of the diodes in the RB through earth connection of my PC.
The reason why the big bang didn't happened immediately after I put the alligator clip to the minus connection of the capacitor
and powered on the psu, was because a bad connection on the alligator clip and the minus pole of the capacitor.
After moving the probe to connect the tip to the NE555 output i finaly made a nice connection on the alligator clip and the capacitor,
but at that point I was very close to the NE555 output pin, even maybe I touched or not, I don't know because the big bang begin.
![](https://i.imgur.com/HX3uBlO.jpg)
So, what you think about my theory?
From my side, it is a simple and common mistake when it's comes to measuring with scope on mains.
