Author Topic: Samsung ue40es5500  (Read 2254 times)
Offline KopernikTopic starter
  • Country: si
Samsung ue40es5500
« on: August 18, 2016, 09:27:08 am »
Hi..
I have a problem with lcd tv.
There is no sound on speakers.. I cannot find a datasheet of audio IC NTP 7412, so I don't now how locate the problem.. any suggestions?
Offline Srbel
  • Country: cs
  • Electronics engineer
Offline wraper
  • Country: lv
Re: Samsung ue40es5500
« Reply #2 on: August 18, 2016, 10:22:07 am »
This? http://pdf1.alldatasheet.com/datasheet-pdf/view/301416/SILAN/SA7412.html
That's completely different IC.
If you cannot find schematic for your TV, there should be others with this particular IC. Try searching from that end instead of searching for datasheet.
