Author Topic: Chassis Feet for FLUKE 540B and FLUKE 343A  (Read 892 times)
Offline Le_BassisteTopic starter
« on: November 17, 2021, 06:51:58 pm »
most often, the chassis feet are missing from old FLUKE equipment. these are *.stl files for
1. FLUKE 540B (set of 4), best to be printed in TPU95. 40% infill, brim recommended.
2. FLUKE 5450A (1 piece), best printed in PLA or PETG, 40% infill. TPU95 isn't rigid enough. also fits 343A and other instruments in same chassis, and has side-rail for intrument-stacking. needs raft and brim to print properly. the three locator pins are slightly too long, simply snip to desired length.
« Last Edit: November 17, 2021, 06:56:14 pm by Le_Bassiste »
An assertion ending with a question mark is a brain fart.
The following users thanked this post: coromonadalix, alm
Re: Chassis Feet for FLUKE 540B and FLUKE 343A
« Reply #1 on: November 20, 2021, 08:44:40 am »
We have a sticky thread for these such things.  ;)
Suggest you also post here where it's easy for anyone to find.
https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/
The following users thanked this post: Le_Bassiste
