Author Topic: Rubber Belt For Printer  (Read 156 times)
Online 2XTopic starter
  • Country: gr
« on: Yesterday at 07:03:27 pm »
Hello,
I have the below rubber belt from an old printer. Do you know where can I find a belt like this or what characteristis I have to find the same... like the diameter, number of seretions?
Offline Jeff eelcr
Re: Rubber Belt For Printer
« Reply #1 on: Yesterday at 07:29:52 pm »
Contact PRB, Projector Recorder Belt Company with all the infomation you did not include they might have one for a ?
Jeff
The following users thanked this post: 2X
Offline Gyro
« Reply #2 on: Yesterday at 07:41:05 pm »
Looking at listings on ebay for timing belts (machine not car, look in the Business, office and industrial section), the quoted dimensions are tooth pitch, eg, 2mm, diameter / number of teeth (both are usually stated) and width.
P.S. They're also known as synchronous belts.
« Last Edit: Yesterday at 07:44:37 pm by Gyro »
Best Regards, Chris
  • Country: gr
« Reply #3 on: Yesterday at 08:27:10 pm »
Also I found the below:
https://in.rsdelivers.com/browse/mechanical-fluid-power-tools/mechanical-power-transmission/belts-pulleys/timing-belts
https://www.google.com/search?q=timing%20belts%20for%20printer&udm=2&tbs=rimg:CTdIbu0pjozyYSPlDMFM5M52sgIAwAIA2AIA4AIA&hl=el&sa=X&ved=0CCYQuIIBahcKEwjQtOrg0YGHAxUAAAAAHQAAAAAQWw&biw=1920&bih=911&dpr=1
Many thanks for your help.
