Author Topic: Fluke 123 OQ0257 T-Asic search  (Read 1038 times)
Offline mario_nksTopic starter
« on: July 18, 2023, 06:54:06 am »
Hello,
I'm looking for an OQ0257 T-Asic to repair my Fluke 123.
Kind regards
Markus
« Last Edit: July 20, 2023, 09:08:40 am by mario_nks »
Re: Fluke 123 OQ0257 T-Asic search
« Reply #1 on: July 21, 2023, 06:39:49 am »
i got one best regards
Markus
Offline ApertureScience
« Reply #2 on: July 22, 2023, 04:00:59 am »
Hello Markus!
Would you mind sharing how you did acquire the part? Fluke Germany recently stated no availability to me. Thanks!
Offline shakalnokturn
« Reply #3 on: July 24, 2023, 11:37:25 pm »
Relative to this topic:
https://www.eevblog.com/forum/repair/fluke-123-124-125-scopemeter-t-asic-needed/
I'm also still in search of one that would cost less than the scope itself.
The other option was design a flexible PCB holding the opamp for the reference voltages + micro conroller for I²C to relay control that would piggyback to the T-ASIC and solder relativley easily to the TQFP leads.
« Reply #4 on: August 02, 2023, 09:42:04 am »
I talked to Markus and he hasn't found the golden pot of Philips Asics. His T-Asic had data lines shorted and removing the short solved the problem. The search continues. I'm gonna check for shorted data lines. If I can't fix it, which I probably can't, I'm gonna sell the meter with good power and data Asic on eBay. Thanks Markus!
« Last Edit: August 03, 2023, 08:08:33 am by ApertureScience »
