Author Topic: Can't locate/ID.this chip for the life of me. Anyone care to take a crack at it?  (Read 1051 times)
Offline FloridaCaveDiverTopic starter
I have spent hours trying to ID and locate this chip. I need to replace one to complete a repair.
I have attached a photo... any help would be VERY appreciated.  There are two of them located on the back of a Keychron V8D2 keyboard mainboard.
I believe it is 22C31WB0c e3
Thank you in advance for any help!
2344089-0
Offline amyk
If you can figure out the pinout, that would help narrow it down as I suspect it's an MCU but there are tons of them in QFN40.
Offline fzabkar
I can't think why one would need two identical (?) MCUs on a keyboard? Am I living in the Dark Ages? :-?
Offline darkspr1te
  • Country: zm
Are there any other chips ? these could be identical MCU's , one is the io keyboard sense side the other could hand the USB side &/or rgb. i would make sense if you already have a build environment and ran out of IO on one chip and didnt want to use a IO expander,
Now if you have maybe 3 chips on the pcb then one could be the actual MCU and the other could be IO expanders. these are just my guess though,
darkspr1te
Offline gamalot
  • Correct my English
    • Youtube
Looks like a customized EFR32BG22 series MCU.
« Last Edit: August 19, 2024, 07:31:43 am by gamalot »
Offline m k
PC and Mac?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline fzabkar
PC and Mac?
I recall PC keyboards where you could select XT mode or AT mode via a switch. They still had a single MCU. I don't think the data transfer rate (2 bytes per second?) has improved since then.
Online Haenk
Now *that* was easy.
"MCU: Ultra-low-power ARM Cortex-M4 32-bit STM32L432 (128KB Flash)"
"The open-source firmware means endless possibilities for keyboard layouts, shortcuts, backlight effects, and more."
https://www.keychron.com/pages/firmware
Offline fzabkar
That's a 32-pin package. :-?
https://www.st.com/resource/en/datasheet/stm32l432kb.pdf
Online Haenk
That's from the product description page, so don't blame the messenger ;)
At least it should help to understand the technology used, maybe they switched to a chinese clone (chip shortage?) - it should still be possible to flash these with their software.
Offline fzabkar
I can't see a crystal or oscillator in the OP's photo ...
Could we see a photo of the whole PCB?
« Last Edit: August 19, 2024, 10:40:31 pm by fzabkar »
Offline m k
More surrounding components would be better.
My take is that 1 is not 1, so 22C3|W[DBO0][O0]c e3.
1st C can be 12, so made 22/2023.
Is lower part of a logo 'together' (hé sī).
E,
obviously C is 12.
« Last Edit: August 24, 2024, 04:24:06 pm by m k »
Online ArdWar
  • Country: sc
If there are wireless version of this keyboard family there might be merit into suspicion that it's a clone of STM32WB series. Not necessarily a full clone, but at least functionally similar. That's what Chinese OEM supplier often do (e.g. STM32WB-like peripherals but using 51 core etc)
« Last Edit: August 24, 2024, 08:22:35 am by ArdWar »
Offline m k
What's 0c then, different package and mask ROM, of version e3?
Offline fzabkar
Offline m k
Maybe end part is a diversion and a real thing is 30ce.
What is that missing pin marking of end of 1st side?
If that last marking is real all sides have hiding pins.
