Well, I have good and not so good news.
The good ones is that the PSU is working fine. So I have been able to boot the unit for first time
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
And then the fun stops... It takes a lot of time on the startup window, showing on
Process BaseDiscoverOptionsBegin ![ThumbsDown :--](https://www.eevblog.com/forum/Smileys/default/icon_thumbsdown.gif)
After several minutes, it continues, shows all the installed options and even the serial number. Once, it has shown a "
non-volatile RAM empty error" after that, but the next time it has not.
Then you can continue, but no function really works and, when trying to do something (as activate the spectrum analyzer), all of them end with a red framed
System Errror window.
Installed software is V 4.51. I have tried to change to V 4.53 (as it is already on the hard disk), but it kept doing the same, so I have reverted back to 4.51
UPDATE: after the N-th attempt, after the red error window and a power down sequence, now it does not boot up!. When you connect the power supply, the GREEN light on the front panel lights immediately after just a blink of the YELLOW one. And that is all!. No fan running, nothing. I have waited for some time, with the PSU disconnected but, so far, it keeps doing the same. The only LED that shines is the 12V Standby (besides the front panel green one!)
Any idea?
Thanks!
Jose
