Update:
Had a long look at those files, in particular the ones dealing with the RxTx module.
Not much luck, even did some mods with my hex editor but just managed to create errors at boot time and sometime lock up the system. Much like what is described in one of the superb repair reports from Mark Michalzik.
The file architecture is not that obvious (to me at least) as to how and where to apply the corrections.
I came across this document from R&S that seem to inply that it could be done in an easy way but it probably requires much unobtanium equipment from mere mortals like me.
""Such frequency responses are usually
measured and stored as correction
MOBILE RADIO Radiocommunication testers
RFIN1 800 900 1075 1800 1905 1980 2000 ;
–50 0.5 0.6 0.7 0.9 1.0 0 –0.5 ;
–70 0 0 0.5 0.6 0.8 0.3 –0.2 ;
–80 0 0 0 0.1 0.2 0.3 –0.2 ;
–85 0 0 0 0.5 0.3 0.3 0 ;
–90 1.2 1 0.4 –0.5 0.4 0.3 0.2 ;
FIG 3
The first column in the correction table designates the RF input or output that is to be corrected.
The frequency points are on the horizontal axis, the level points on the vertical axis. The other table
entries are the correction values. A semicolon indicates the end of a table line. During operation, the
correction value is linearly interpolated between the individual frequency points; there is no interpolation
between the level points. The frequency and level points are user-definable. A correction table
can contain a total of 120 values.
The user-specific correction of frequency
response and level response of the Universal
Radio Communication Tester
R&S CMU200 is designed to be versatile
(FIG 1, 2). Separate correction tables can
be compiled for each RF input and RF
output. The user is free to decide on the
User-specific correction of frequency response and level
response: a snap with the R&S CMU200
13
number of frequency and level points
to be set up. The tester linearly interpolates
the level correction to be used
between the frequency points. The correction
tables (FIG 3) are easy to compile
on any PC by means of a normal text
editor, or automatically by a measurement
program, and are then loaded into
the mobile radio tester via the IEC / IEEE
bus, RS-232-C interface or PCMCIA card,
where they can be activated or deactivated
at any time. ""
The whole file is way too big to post as pdf but can be found on the R&S site in the news bulletins as: News from Rohde&Schwarz Number 177 (2003/ I)
or
https://cdn.rohde-schwarz.com/pws/dl_downloads/dl_common_library/dl_news_from_rs/magazin/Neues177_englisch_72dpi.pdf"a snap with the R&S CMU200", ya,sure :
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
