Author Topic: TEKTRONIX 2465 with DMM Test 76 Fail 01  (Read 901 times)
Offline LennyTopic starter
« on: December 16, 2017, 04:31:23 pm »
Hello,
I have a problem with my Tek Scope. It shows Test 76 Fail 01. The maual says Malfunction of DMM, or if this is the only failure V/F input Multiplexer U5020 input pin 2.
I recapped the PSU and the DMM. I already changed U5020, but the fault is still there.
I can ignore the fault and use the DMM with no problems.
Does anyone have any Idea what to to?
Lenny
« Last Edit: December 16, 2017, 06:34:07 pm by Lenny »
Offline Testtech
Re: TEKTRONIX 2465 with DMM Test 76 Fail 01
« Reply #1 on: December 21, 2017, 07:11:35 pm »
I would recal the DMM and see if that fixes it.
