Author Topic: rigol ds1052e fallo  (Read 1404 times)
Offline MortysTopic starter
rigol ds1052e fallo
« on: November 17, 2022, 06:57:36 pm »
Hello, I hope you can help me. I have a problem with my ds1052e. I send you screenshots. No channel measures me. There is only noise. It appeared from one day to the next.
Re: rigol ds1052e fallo
« Reply #1 on: November 17, 2022, 07:08:54 pm »
estoy desesperado puedo mandar video
« Reply #2 on: November 17, 2022, 07:41:57 pm »
ahora se queda enm la pantalla de carga
Offline MikeK
« Reply #3 on: November 17, 2022, 07:44:01 pm »
Why do you have the timescale set to 50 seconds?!
Offline MikeK
« Reply #4 on: November 17, 2022, 07:46:00 pm »
Attach CH1 probe to the 1kHz signal output, hit Auto, and then discuss the results.  Or probe some other known signal where you think you are seeing something that you shouldn't.
« Reply #5 on: November 17, 2022, 08:41:07 pm »
now it has stayed like that
Online Adrian_Arg.
  • Country: ar
« Reply #6 on: November 17, 2022, 08:43:54 pm »
try factory reset and if not see if you can flash it
proba reset de fabrica y si no fijate si podes flashearlo
« Reply #7 on: November 17, 2022, 08:50:14 pm »
how do you do a factory reset please
Offline R-1125F
« Reply #8 on: November 17, 2022, 09:08:01 pm »
The following users thanked this post: Mechatrommer
Offline R-1125F
« Reply #9 on: November 17, 2022, 09:38:24 pm »
If that does not work, then reload the firmware.
You can download firmware for the DS1000E from Rigol.
https://www.rigolna.com/firmware/
Then
1.Copy .RGL file to the root of USB flash
2.Power on DS1000E/D/U, insert USB into DS1000E/D/U, there will be a note that find a new firmware whether to update. Press update button
3. After finish update ,reboot and check the version
Note: Do not power off the instrument or move the USB flash during the updating.
« Reply #10 on: November 17, 2022, 11:51:43 pm »
it does not recognize the usb it stays the same and some beeps sound
« Reply #11 on: November 18, 2022, 04:52:21 pm »
alIs there a thread on how to reprogram the eprom?
Offline MikeK
« Reply #12 on: November 18, 2022, 08:08:09 pm »
Maybe someone has more info.  I found this:
https://www.eevblog.com/forum/repair/repair-bricked-rigol-ds1052e/
Offline R-1125F
« Reply #13 on: November 18, 2022, 10:39:36 pm »
Contact Rigol before you start trying to fix it yourself.  They may have something that will boot from the USB drive.  They were very helpful when I had a problem with my DS1054Z.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #14 on: November 18, 2022, 10:41:52 pm »
i also bricked mine... it can be programmed with JTAG J-Link, but since its unreliable, i bought XGecu programmer and desolder the Flash.. first it was out of calibration like in OP picture, yesterday i tried opening it again its now just blank, but i did save the Flash content, maybe later i'll try to reprogram again, i think something is rotten down after 10+ years of life.
https://www.eevblog.com/forum/blog/the-dark-side-of-the-rigol-hack-bricked-scope-how-to-fix-it/125/
good luck, its 10+ yrs old DS1052E version.
« Reply #15 on: November 18, 2022, 10:48:08 pm »
Thanks everyone for your help
« Reply #16 on: November 18, 2022, 10:51:31 pm »
If you manage to repair it, let me know because the person who reprogrammed it for you is no longer here?
  • Country: my
« Reply #17 on: November 19, 2022, 01:38:44 am »
yes Drieg is missing. if he is around things will be much easier.
