Author Topic: Rigol DP712 failed for no obvious reason  (Read 1020 times)
Offline AndersJTopic starter
« on: July 10, 2020, 04:41:27 pm »
The power supply suddenly failed while delivering 24V at 100mA.
It displays "Analog board failed in self-inspection".
Any ideas?
Sorry about the image size and orientation.
I am unable to shrink it, or rotate it.
Maybe I am too stupid to own a Rigol.
« Last Edit: August 26, 2024, 11:00:35 pm by AndersJ »
"It should work"
R.N.Naidoo
Offline Akai
Re: Rigol DP712 failed for no obvious reason
« Reply #1 on: August 26, 2024, 07:49:34 pm »
Hello
I also have a DP711 with the same error, the text comes up immediately when switched on.
Have checked what I can check, +14V, -15V, Rectifier, OP Amplifiers etc..
One might suspect "CHIPSEA" CS1232 (Analog to Digital Converter)
Can these have a "service menu" where you can go in and see and test functions manually?
« Last Edit: August 26, 2024, 07:54:10 pm by Akai »
