An anti-static rubber mat would help to avoid scratches and ESD problems.
Yep that it's correct but i don't have one yet
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
, im thinking to buy one if you have something to suggest ..
I found this one
http://www.ebay.co.uk/itm/Professional-Antistatic-Mat-ESD-PC-repair-earth-clip-/400281021082?pt=LH_DefaultDomain_3&hash=item5d329baa9a#ht_4177wt_1163But i don't know about the quality .
Hey what happen there?
The heatsink came loose because the hook came off???
The little U clip gave in? Too much heat caused it to desolder or really bad soldering in the first place, what do you think?
Oh man I got the same model just last week, now you got me worried...
I have to say 3 things about the teardown
First take apart this scope is relay easy all the screws its the same and in every hole need one the have a indication.
The motherboard seems really nicely design and the soldering seems like a first class.
Except the hand soldering parts this is where the blow it up , i found cold joints and because of that probably the clip came off .
I don't thing that the heat its melt the solder, when i try to resolder it i put the soldering station in 480C to melt it.
In the video seems that its only one clip drop from the scope but accusal it's two clips that are missing , both the heat sings it's stuck in the chips with only the thermal paste and with
any vibration it can came off damaging the scope , talking about damage i lucky that the floating metallic parts don't make any damage in the first place.
Thirdly, in the scope i found 1500mbit of ddr2 ram , i mean im sure that this scope it's capable to make more than 54mpt capture, in the record mode you can record 2 waveforms of 54mpt so this is 108mpts hmmmm ..... maybe with some sort of hack we can unlock the true power of this scope
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Astroplio probably the your scope it will be fine just try to shake it and hear for any noise if it's make just sent it back.
But let me tell you two more thing, fist careful with the probes it's relay not that good, it's the second time that my probe is cut and im not the kind of user that i don't care my staff and second DO NOT make a auto calibration, it will expire the trial version modules.
What you guys thing about the power supply it's any good ??
edit: 1500mb -> 1500mbit
