Author Topic: Rigol 1022u doesen't boot up [SOLVED]  (Read 3671 times)
Offline NiaDebesisTopic starter
« on: December 11, 2017, 09:46:28 pm »
Hello
Today I haveonstalled the new firmware
With the message "cal value has been saved, reboot"
After the reboot it boots up but the screen is black
What I have to do?
« Last Edit: December 22, 2017, 07:41:13 pm by NiaDebesis »
Re: Rigol 1022u doesen't boot up
« Reply #1 on: December 11, 2017, 10:05:25 pm »
I really need help...
« Reply #2 on: December 12, 2017, 02:21:45 pm »
Up..
« Reply #3 on: December 12, 2017, 06:06:41 pm »
The lights remain stucked like in the photo
http://imageshack.com/a/img924/8296/za4jMw.jpg
Firmware version before the update
http://imageshack.com/a/img922/9580/b1Dx4q.jpg
I need help..I don't know what to do, I have turned my function gen into a paper weight.
Offline Armadillo
« Reply #4 on: December 12, 2017, 06:34:23 pm »
Seeing your firmware version indicates that you have not read the instruction manual to upgrade.
Press the view then power on to see the complete 18 digits Version number actually.
Have you tried to contact Rigol. I trust you downloaded the upgrade from their site.
Edit: I saw your the "other" post. Since the official source is in contact with you, you should seek from them.
« Last Edit: December 12, 2017, 07:10:15 pm by Armadillo »
« Reply #5 on: December 12, 2017, 07:25:07 pm »
Wich other post?
And pressing view does nothing..
Offline Armadillo
« Reply #6 on: December 12, 2017, 07:36:20 pm »
My mistake, that's not you.
you have to update 2 files.
One is the bootloader.
then the other is the dsp file.
Which GEL have you upgraded?
Offline Armadillo
« Reply #7 on: December 12, 2017, 07:44:11 pm »
If you have only upgraded the bootloader which you should, then all the light will lights up.
follow these steps [by IU8BBM]
You need to download the updates from the official source with your serial number *****************
0) Download all the required files, attached to this post
1) Turn off instrument
2) Disconnect the USB cable used for PC connection from the back USB B slave port
3) Pressing  repeatedly the HELP button, turn on the instrument
4) Boot will be stopped, the only MOD led button will turn on, stopping booting sequence
5) Insert USB Stick where previously you have been saved on the root the "DG10x2Update.GEL" file unzipped from "DG1022X(DSP)Update(Bootloader).rar"
6) Wait until all led will stop blinking (around a minute)
7) Turn off instrument
8) Repeat steps 3-5 with the GEL file from "DG1022X(DSP)Update(Normal).rar"
9) Wait until all led will stop blinking (around 3 minutes, will start blinking up to the ARB button)
10) Turn off instrument
11) Turn on instrument
« Last Edit: December 12, 2017, 07:46:35 pm by Armadillo »
« Reply #8 on: December 12, 2017, 07:47:18 pm »
When I put the usb stick -mod,store,burst remain lights up and doesnt turn off
« Reply #9 on: December 12, 2017, 07:48:11 pm »
When I put the usb in
Mod store and burst remain on and thats it
Offline Armadillo
« Reply #10 on: December 12, 2017, 08:11:19 pm »
If your files came from Rigol, you should contact them for support.
« Reply #11 on: December 12, 2017, 08:15:20 pm »
 Ill do know..thanks always..
Offline Armadillo
Re: Rigol 1022u doesen't boot up [SOLVED]
« Reply #12 on: December 19, 2017, 04:44:46 am »
I contacted China Rigol and they are great people, Regional Manager and Engineers all robed in to resolve the problems. Hope it will help others here.
OK here is the repeatable problems and the solution;
Before Update, you can clearly see the old version number
During Update the Mod button, Store/Recall button, Burst button light up and no visual cue as to what is happening.
Reboot and Hanged. All the Buttons light up [except Ch1/Ch2 button]
Problem Solved. Firmware Updated Successfully.
« Last Edit: December 19, 2017, 05:14:09 am by Armadillo »
The following users thanked this post: NiaDebesis
Offline Armadillo
« Reply #13 on: December 19, 2017, 04:56:33 am »
The solution is;
You must only use "LESS THAN 4GB THUMBDRIVE"
I repeat: "LESS THAN 4GB THUMBDRIVE"
I use 2GB thumbdrive to solve the problem.
1) Immediately after power up press the "Help" button. The "Mod" Button lights up. [Do not plug in the thumbdrive]
2) Use the 2GB thumdrive with the 2nd GEL file in the root directory, plug into the front USB drive.
3) The Store/Recall button lights up, then after Sine, Ramp, Pulse, Noise, Arb, "INDIVIDUALLY" one by one blink blink blink and lights up.
4) Finall All the buttons light up.
5) Power off and reboot.
If this solve your problem, click the thank button to appreciate Rigol China for their quick solution.
« Last Edit: December 19, 2017, 05:05:32 am by Armadillo »
« Reply #14 on: December 22, 2017, 06:27:14 pm »
The solution is;
Wich file? The 'normal'? And..thank you very much..very very much..Ill try this tomorrow
« Last Edit: December 22, 2017, 06:48:07 pm by NiaDebesis »
« Reply #15 on: December 22, 2017, 06:42:11 pm »
And I have to wait the mod button to go down at the first step?
« Reply #16 on: December 22, 2017, 06:49:09 pm »
I have tried to do it with a microsd (2gb) to usb adapter, but nothing
« Reply #17 on: December 22, 2017, 07:40:51 pm »
Man, really, thank you very much!! Now it works, I have also used a 4Gb pendrive, my other usb stick wasn't recognize by the instrument, really, thank you very much!!!!
Offline Armadillo
« Reply #18 on: December 22, 2017, 08:12:33 pm »
Your testimony is important, cause people may at the hindsight, think that it's silly solution. LOL.
So, grab those defective bricked DG1022 selling cheap on the ebay.   :-DD
« Reply #19 on: December 22, 2017, 08:37:30 pm »
Ahahah, unfortunally the rigol1022u isn't that good, at max freq a 10Vpp amp became a 5Vpp
The lcd test isn't well designed
When I perform a SelfTest ot display *output overload* and finally "seltest pass" that isn't a problem, but why?
Anyways, thank you very much! The support evend doesn't reply..
Offline Armadillo
« Reply #20 on: December 22, 2017, 09:12:39 pm »
I cannot repeat your problem. At 25Mhz, 10Vpp Sine Wave is displayed on my Oscilloscope as perfect sine and 10Vpp.
Common mistake is, plug output to CH2, but adjust on CH1 parameter and vice versa.
« Last Edit: December 22, 2017, 09:14:32 pm by Armadillo »
« Reply #21 on: December 22, 2017, 09:44:53 pm »
Didn't terminated the oscilloscope..such a genius
« Reply #22 on: December 22, 2017, 10:03:52 pm »
Nope, it has something wrong, I have well terminated the scope and tge F.G but nithing, at max freq the amp is 2 time smaller conpared to the settings
Offline Armadillo
« Reply #23 on: December 22, 2017, 10:35:57 pm »
This problem has nothing to do with boot up hence I suggest that you open up new thread for your peculair problem.
Offline sprint
  • Country: cn
« Reply #24 on: August 20, 2020, 06:23:15 am »
Thanks & Mark
