Hi all,
I'm hoping to get some advice from the forum.
I have just purchased a Riden RD6012PW complete kit (bench adjustable PSU, fixed source PSU and enclosure) from RD Official Store on Aliexpress.
The fixed source backend is an 800W 65V 12.3A SM PSU.
It is the same make and almost the same model of PSU as the one in this youtube video...
https://youtu.be/zzW0DvattfM?t=76According to this video this PSU uses a relay to bypass the PTC inrush current limiter after a set time, or a certain voltage is reached across the capacitors.
mentioned here
https://youtu.be/zzW0DvattfM?t=142and here
https://youtu.be/zzW0DvattfM?t=241I suspect it is a bit like this...
![](https://www.ametherm.com/images/ptc-limiting-circuit.PNG)
from here
https://www.ametherm.com/inrush-current/ptc-thermistors-for-inrush-current-limitingBUT
on my copy of the PSU, the switch side of the relay is not soldered into the board.
As you can see in these photos the switch side is sticking up in the air with unconnected pins.
![](https://www.eevblog.com/forum/repair/riden-rd6012pw-complete-kit-psu-issue/?action=dlattach;attach=1452946;image)
This is the underside of the board
![](https://www.eevblog.com/forum/repair/riden-rd6012pw-complete-kit-psu-issue/?action=dlattach;attach=1452952;image)
The PSU does appear to be working although I have not put any load on it yet. I suspect if this has a impact on the PSU it would only be obvious at high current loads as the PTC is not being bypassed.
My questions are
1) Do you think this is intentional or accidental? and,
2) Should I try to return it, or just solder the relay back in and hope for the best?
cheers
