Hi EEVbloggers,
I have pulled apart the DS1742W-120+, here is summary:
Draft Pin Details:
Pin 1 - Notched - Straight Through (A7)
Pin 2 - Notched - Straight Through (A6)
Pin 3 - Notched - Straight Through (A5)
Pin 4 - Notched - Straight Through (A4)
Pin 5 - Notched - Straight Through (A3)
Pin 6 - Notched - Straight Through (A2)
Pin 7 - Notched - Straight Through (A1)
Pin 8 - Notched - Straight Through (A0)
Pin 9 - Top Side R1, Under Side T1 (DQ)
Pin 10 - Top Side R5, Under Side T2 (DQ)
Pin 11 - Top Side R6, Under Side T3 (DQ)
Pin 12 - Notched - Ground Layer (Battery -Neg)
Pin 13 - Top Side R7, Under Side T6 (DQ)
Pin 14 - Top Side R8, Under Side T5 (DQ)
Pin 15 - Top Side R9, Under Side T5 (DQ)
Pin 16 - Top Side R10, Under Side T9 (DQ)
Pin 17 - Top Side R11, Under Side T8 (DQ)
Pin 18 - Notched - Straight Through (^CE)
Pin 19 - Notched - Straight Through (A10)
Pin 20 - Notched - Straight Through (^OE)
Pin 21 - Notched - Straight Through (^WE)
Pin 22 - Notched - Straight Through (A9)
Pin 23 - Notched - Straight Through (A8)
Pin 24 - Top Side C2 (VCC), Under Side C3 (10A45)
Draft Components
Capacitors x 3 (10A45)
Resistor x 8 (102) - 1 per Data Line
Voltage Regulator IC 6 PIN 10A45
Oscillator Crystal (Pin 1/24 Notch)
Battery Cell - 3V CR1225 (+Pos Pin 12/13 Notch, -Neg Pin 12)
Here are pictures of PCB board that is encased in epoxy and sits underneath the main IC:
And here is carefully cut chip with battery extracted:
Full details of drilling/heating and cutting:
https://tips.graphica.com.au/sgi-nvram.
If someone else has nice pre-built replacement then I think I would just use that ... ;-)
Cheers from Oz,
zebity/jwhat/John
